BUSH dfta12hd SET TOP BOX
I RECENTLY BOUGHT THE ABOVE SET TOP BOX AND INSTALLED AS PER THE MANUAL. (I HAVE FOXTEL AND A PLASMA TV ) USING THE RED/YELLOW/GREEN SOCKETS (together with the r/y/blue)
NO MATTER WHAT I DO WHEN I TUNE IT IN I ONLY RECEIVE THE ABC HD CHANNEL AND NONE OF THE OTHERS. I'VE LINKED IT TO THE FOXTEL BOX AND ALSO AN OUTSIDE ARIAL AND I GET THE SAME RESULT.
ANY SUGGESTIONS???
5 Suggested Answers
  • 5 Answers
SOURCE: Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Posted on Feb 04, 2008
SOURCE: MANUAL FOR HD SET TOP BOX
Try this link. Ijust downloaded the manual from here myself.
http://www.dgtec.com.au/arbitrage/pages/134/DG2000A+UserManual.pdf
Regards
Graham
Posted on Jul 21, 2009
SOURCE: we cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Posted on Aug 24, 2009
SOURCE: i have set up the sky box to have the RF power on
When you are in the rf mode there will be a number ,normaly 68.You may have to change it to another number ie 32 and try retune
Posted on Oct 06, 2009
  • 736 Answers
SOURCE: connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Posted on Jan 27, 2010
I would like to find out the TV code for my 55' Bush tv so I can programme my sky TV remote please.
Hi Darren, I have Sky (foxtel) and the Sky box (foxtel box) is hooked up to my television and the only thing is i turn the volume up to full on the television and control everything (volume and change channel) through my Sky(foxtel)remote control..... I hope this helped, CHEERS..
Mar 31, 2016 | Bush Televison & Video
I have a jvc lcd colour tv lt32d21 model 2010 with a jvc remote. i also have a foxtel iq set top box with foxtel remote.
It will be best for you to download the user manual to your TV. www.retrevo.com/
Check this site to download it for free. It has all details. Electro help
Oct 23, 2014 | JVC AV-32260 32" TV
I today had to reset my foxtel as i have been having problems with it, and ever since I reset it i have lost all TV channels. I have rescanned for the channels and it says there is no antenna connection. I...
Hello
Just set your TV idle for external or internal afiel connection and set ti to autotune, and see if all the transmitting stations are memorized or not. Then reconnect the devices one by one and try to find the faulty device.
Seelct autoprogramme, select antenna in and select auto and then all channels. You can refer this porocedure in its manual. OK.
Feb 21, 2011 | Panasonic Viera TH-50PX80U Plasma TV
How to connect a dvd recorder ( & player ) a VCR & Foxtel to a plasma THP46G10A do you have diagramatic sketch of connections
samsung 42" plasma hooked up to LG vcr/dvd combo and foxtel IQ box. all working but only by plugging vcr cable into video camera sockets on side of plasma tv?? reason only place with a yellow plug socket? on rear of tv colours are only red,green.blue? and white. nothing for the yellow can you give any advice on correct hookup proccedure please.
Dec 18, 2009 | Panasonic Televison & Video
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
Manual for bush dfta5a not supplied at purchase.
I have the Bush DFTA1A set top box and plugged the aerial into the back of it, then connected the 3 cables red,white & yellow also into the back of it and the other end of those cables into my DVD/TV. then follow onscreen prompts to install it. works fine.
Aug 25, 2009 | Bush DVD2038 DVD Player
Bush dfta16 set top box device code
What is the model number of the remote? It seems to me that Bush may not be a supported device.
Dec 05, 2008 | RCA Universal Remote Control
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
I have just installed a Teac SDB451 set top box for a friend and I have installed antenna to it then used the video and audio outs to their vcr and vcr to their TV. I can get a picture using the set top...
Go to http://vk3khb.gak.net.au/atv/chnlchrt.html#TV_Table
I went there and checked the details vs those appearing on my STB. Went through the manual channel search and changed the frequency to those on the above website. Now all channels work perfectly. I only bought this STB because my last one froze, it appears this one doesn't have the best auto search facility but with a bit of tinkering it will work for you!
Aug 30, 2008 | Televison & Video
LG plasma buzzing
Problem is probably with your cable box as you have confirmed that the set is working by using the dvd player, that is unless you have a bad cable for the cable box.
Aug 12, 2008 | LG Televison & Video
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
Electro Med Services...
