Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Elite, Model # 106 50599003 Icemaker
I have a Kenmore Elite Model 10650599003 fridgerator and the Ice maker caddy lives inside the door of the freezer. The ice caddy is designed so you can pull it off and dump your ice into an ice chest. When I pulled it off the lower part of the caddy had some ice build up and caused the plastic parts and spring to fall out. Nothing broke so I put it back together but now it no longer works. I'm wondering if the spring was damaged and thats why it doesn't work. Are these parts available?
  • Reb1277 Jan 09, 2009
    We have the same problem. Have not been able to locate parts. For such an expensive refrigerator does not seem to be made well. Will not by a Kenmore product again.
icansurf
  • 72 Answers
SOURCE: ice maker thru the door
usually due to rust or crud build-up. try lubricating moving parts with WD-40, or possibly removing accessible screws/bolts and manually cleaning it up.
Posted on Jul 11, 2007
  • 958 Answers
SOURCE: kenmore elite - top freezer
if there is ice build up at the back wall of the freezer section, then you have a problem with your defrost cycle. the freezer would not be very cold for the ice maker to work.
it's either your timer, defrost heater or your bi-metal.
tnx 4 using fixya,
drcool
Posted on Sep 30, 2008
  • 3 Answers
SOURCE: Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Posted on Apr 02, 2009
  • 351 Answers
SOURCE: Ice maker broken
first if you take off that panel there is a circuit board . unlpug the board and put it back to gether if that dont work then replace it... i sometimes get away with both! i can also get you that part pretty cheap... here is my site. grab the number and give me a call thanks.
Posted on Apr 30, 2009
arikrom
  • 528 Answers
SOURCE: Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Posted on Jan 02, 2010
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
How to fix icemaker in fridgerator
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Dec 16, 2010 | Kenmore 53642 / 53644 Side by Side...
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore side by side elite. I have installed a new ice maker. I can not get water into the ice maker. The extraction teeth rotate and I get water through the water port on the door but not into...
Usually happends that the solenoid (electric valve who opends when the ice maker calls for water) leaks and this water freezes up inside the filling tube for the ice maker , t he solenoid has to be replaced.
Sep 20, 2009 | Refrigerators
Kenmore Elite Bottom Refer Internal leak
Hi, look and make sure the inlet tube to the icemaker is inside the fill cup. Make sure there is no ice build up in the fill tube also.
I hope this helps some, please let me know if I can help further.
Thanks Vic
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker doesn't work.
TROUBLESHOOT THE ICEMAKER ON THE 54606300 SIDE BY SIDE REFRIGERATOR
May 02, 2009 | Kenmore 54603 / 54606 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
958 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
