Question about HP Office Equipment & Supplies
Hi ,My Hp5000 printer started out of the blue printing continuous lines down the left margin .Sometimes its seven lines & now 2 to 3 lines.How can I stop this & what caused it ? I'm needing to print an important document urgently. Thanks Barry Pilbeam
    Guru:
  • 558 Answers
Hi Barry,
Thanks for the posting in FixYa.
If only the blue color is not shown after printing may be the Color Catridge having problem or may be getting empty.
Try after inserting a new Catridge. Otherwise clean the roller of the printer may be they get struck with the ink.
Regards
ELLIN
Posted on Sep 17, 2008
  • Puneet Jain
    Puneet Jain Oct 17, 2008
    Reply please if the soluton work for you.
    You can try to clean the nozzle of Cartridge and contact film of the Cartridge and printer rack  (most of times it works)
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me
    know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
When printing continuous Quicken checks with the Epson LQ-590, the first check prints perfectly but the second check prints about 2 lines lower than the first check, then the third check prints 2 lines...
It can be the margins set within the printer defaults or the margins set by Quicken. In your print preview within Quicken you should be able to see where the margins are set and adjust accordingly. Otherwise, you may need to go to your Epson's print queue and adjust the properties directly on the printer. A nice way to check it is to see if you can print some test checks to plain paper and adjust as you see fit!
Dec 07, 2009 | Epson Dot Matrix LQ-590 Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Bottom of page is cut off sometimes printing from vista computer
Hi- I'll try to solve this.
Go to the start menu and open the Control Panel. Double click on Printers. Right click the L7580 printer and choose "Printing Preferences" On the preferences window click on the "Advanced" tab. Make sure "Advanced Printing Features" is set to "Enabled" Under "Printer Features" turn "Minimize Margins" to "On"
This should solve the issue. If minimize margins is off, it will cut it off at the bottom.
Feb 06, 2009 | HP Officejet Pro L7680 All-In-One Printer
Samsung CLP-500 output problems
i have found that removing the toners, and shaking them side to side, while keeping them horizontal, which seems to spread the toner for even distribution. This can sometimes fix the problems with fading prints. hope it helps.
Margins i think might be a problem with the wysiwyg of the program, some don't do it well, but also excel in particular has a shrink to fit page option, you may find the percentage not at 100%. you can also copy an excel table to word and print from that if it is driving you nuts.
Jan 23, 2009 | Samsung CLP-500 Laser Printer
11 blue dots print out down the left hand side of documents
it sounds like the CYAN toner cartridge is leaking.
Jan 22, 2009 | Office Equipment & Supplies
How do I reset the drum life of a DCP7010
never ver use refil toner on brother products. to answere your first question 1 open the front cover 2 push menue button scroll down to machine info press set buton 3 scroll down to drun lif - push set
Jan 09, 2009 | Brother DCP 7010 Multifunction Laser...
Printer setup
Continuous forms paper fed through the front of the printer also uses either the Front Push, Rear Pull, or Push-Pull tractor configurations. Make sure this is set correctly or it will reverse your margins.
It could also be your software. When you print through windows it's using the Microsoft system font controller, but your software could be setting font, margins, and alignment by the settings in the printer not in the driver. So if the first doesn't work, set your system back to align left then go into the printer configuration menu on the device and adjust the margins there.
Dec 15, 2008 | IBM 4247 Model V03 Matrix Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Error 0F0100030C099F on hp5000
found this maybe can help i dont know
I tried the fix of :
This may be an error finding the mark encoder. The mark encoder is the
white plastic piece on the left end of the roller. Replace the lense cover
first. If the error remains, turn the printer off, and place a piece if black
tape over the hole at the left end of the drive roller, this will block the
mark encoder from the line sensor and should trigger a 010092 error during
power on. When the 010092 error comes up,
press enter to continue past the error. After the printer comes ready, remove
the tape, and run a scan axis calibration.
To run the Scan Axis Calibration:
1. Enter "Device Setup".
2. Enter "Utilities".
3. Press the UP arrow and ENTER keys simultaniously,
4. Select "Yes".
5. Enter "Service Calibrations".
6. Run the "Scan Axis Calibration".
May 30, 2008 | HP DesignJet 5500PS InkJet Printer
97 people viewed this question
Seeker5211
Seeker5211
