there is a good disk in it and it will run for about 15 seconds then say bad diskthere is a good disk in it and it will run for about 15 seconds then say bad disk
You can't post conmments that contain an email address.
The Clicking sound happens, when the lens which reads the cd's,dvd's move off from its original position, this happens when the particular equipment is moved or pushed. In some rare cases, when you insert a very scratched cd, dvd. This can be solved by the particular tv company technicians, or else your warranty will be void.
Try checking whether the lens works perfectly, by playing different kinds of content ( audio cd, mp3, dvd ) etc... If any works, then your lens is working perfect. Later, try cleaning the lens using the " cd lens cleaner kit ". It will be available in any computer accessories related shop.
So far you cannot. The only way for it to work is to burn the map file onto a DVD DL disk. But the Avic D3 cannot read those disks. Currently Im trying to burn the map file along with music files to see if it an all work at once (cutting out the need to switch disks). So far, no dice. Ill post up the process once I get it to work
We currently have some secondhand dvd drives in stock, Samsung MS28's and Hitatchi 78fk. Both working ok and taken out of working machines that had 3rrod. We also stock all other parts www.fixmyconsole.co.uk
Good luck setting up a business m8, the best advice is to do some research and learn every fault and repair to the point where you know it by hand.
Im just wondering, are you a kid, because your writing in text message form! Try getting the reset disk offline as an iso image, you will also need a dvd drive, dvd-rw, and and iso burner(this is free)! Then burn it to the disk!
