Even with a new battery, the battery will NOT take a charge, Laptop will not work unless plugged in to the wall.
  • 4,472 Answers
Ok then it is an internal problem. You can have the laptop serviced. How long have you owned the laptop? Please don't request more help until I have gotten all the information necessary to assist you properly.
Thanks,
Lee
Posted on Sep 17, 2008
  • Lee A.
    Lee A. Sep 18, 2008
    one thing you may need is a new AC power cord. It could be the cord
    itself that is bad. If you can find someone elses to try that may help.
    The other thing that it could be is the internal recharging circuitry.
    It is one or the other. First I would try a different power cable. If
    that doesn't help you will need to get your laptop serviced. If you
    have a moment to accept and rate this solution
    appropriately it would be greatly appreciated.
    Thanks,
    Lee
Kodak easyshare won't work unless plugged into charger
Hello Pam, You have either a faulty contact for the battery or your battery is suffering from age. After time these camera batteries lose their capacity. Try a new fully charged battery.
Best Regards, Russell
Jan 11, 2013 | Kodak EASYSHARE M340 Digital Camera
Battery won't charge
Sounds like you have a broken AC plug. You can buy them cheap and disassemble the laptop and soldier the new one in but unless your electronically capable I wouldn't try it yourself. You can Google your laptop model number and watch videos to help if you insist on doing it yourself.
Aug 11, 2012 | Toshiba Satellite A215-S4807 Notebook
Laptop won't come on even when plugged to wall outlet
you will likely need to remove the battery pack to run the unit. If this works, you will need a new battery to use the laptop portable.
Jun 09, 2012 | Acer Computers & Internet
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
My dell latitude d600 won't recognize the AC power adapter and doesn't show that the battery (which is new) is charging. I had to leave it plugged in for about a week when I put in the new battery before...
There was a class action suite against Dell for this problem with this model laptop due to overheating and destroying the power supply. Browse the web for more information. I have one and it is a parts machine now.
Jul 29, 2009 | Dell Latitude D600 Notebook
Acer aspire 3680 laptop will not charge while plugged in wall
It appears that you have faulty laptop power connector socket.
This is why it appears to work sometimes when you plug the connector into the laptop in some direction.
To confirm this, wriggle the connector while you look at the charge light on the laptop, if it blinks as you wriggle it then the power socket is either faulty or just needs resoldering so it will make proper electrical contact.
You can get a compute techo to do this or you can do it yourself but it requires dismantling the laptop completely to get at this power socket.
Jun 01, 2009 | Acer Aspire 3680 Laptop
Will not come on or be installed
Many laptops do not have enough power resources to keep an mp3 player charged/properly functioning. To test, you will need to close all running programs, and devote the laptop solely to the function of charging the mp3 player (the laptop will need to be plugged into a wall outlet even if it has its own battery). This is not a guaranteed fix, but it is your only hope with a laptop. You will not experience the same problem on a desktop unless that mp3 player's hardware itself is faulty.
-Tha Mp3 Doctor
Dec 18, 2008 | RCA OPAL M4001 MP3 Player
BATTERY is charged, but will not work without being plugged in
Your battery is old and worn out, even though it indicates as fully charged. The battery capacity is practically zero. Rechargeable batteries have a finite number of charge and discharge cycles.
You need to buy a new battery if you wish to use the laptop without connecting to the mains.
Dec 01, 2008 | HP Compaq Evo n610c Notebook
HP Laptop Battery problem
there is some circuit loosing inside the laptop's battery connection. it need to oprate technically.
Nov 08, 2008 | Computers & Internet
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
David Payne
David Payne
