Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Panasonic PT-61LCX65 Bulb Reset
Just replaced my bulb - wanted to reset the lamp timer but my controler does not have a PIP or SWAP button... IDEAS?
  • rextynes Sep 30, 2008
    I have the same problem. I cannot reset the lamp I do not have a "PIP" button so I tried the "swap" button.
    Rex Tynes
Hold the volume button down on the t.v. & the split button on the remote at the same time for about 8 to 10 seconds.The t.v. tech. did this with my panasonic 61lcx65. Also I had 2 fairly large red / orange & 1 blue spots on the screen which I thought were a result of the bulb being bad , but the tech. attached a device he called an eeprom jig & it reset the chip ? Now the picture is like new again.
Posted on Sep 20, 2008
Do to the reset, you must hold the volume down button on the TV and the split button on the remote for about 5 seconds.
Posted on Mar 04, 2011
  • Cherish Arnold
    Cherish Arnold Jul 18, 2017
    I have done this, but it is not working...any other ideas
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
Changed bulb, but cannot get blue" change bulb and reset hour meter "banner off tv
You need to use the remote control that cam e with the TV and press the PIP/SWAP button on the remote and the VOLUME down on the front of the TV simultaneously for more than 10 seconds. Once successful the on screen display will tell you the lamp timer is reset to 0.
Sep 08, 2010 | Panasonic PT-50LC14 50" Rear Projection...
I have replaced the bulb but still keep getting a Reset Notice
Hold Vol - on tv and TV/Video button on remote same time for 5 seconds. serv menu will come up. select lamp time and reset with vol- on remote to zero. Turn off tv to remove menu.
Nov 22, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
LAMP REPLACMENT
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Dec 23, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp reset
Turn on the tv. On the tv itself, push and hold the volume down button. Then on the remote, where it has split/swap button, press and hold the swap (down) button while pointing remote at tv.
hth
Jun 28, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT61LCX65 lamp timer
Hold the volume down button on the tv until the volume is at min. then continue to depress the volume down button on the TV. While depressing the volume down button the tv hold the pip or split button on your remote for approx 5 sec. You will see a box pop up that says lamp timer reset and gives instruction on how to exit.
Jun 02, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
2,322 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
