A/C WON'T COOL
FAN WON'T STAY ON FOR MORE THAN 30 SECONDS.
  • 3 Answers
Fan on ac unit out side or on furnace
Posted on Sep 17, 2008
When I turn the engine off the engine cooling fan stays on and does not shut off
depending on the engine temperature the fan is supposed to remain on after you turn the engine off, until the engine reaches a preset cooler temperature. when it reaches cooler temperature usually within 5 minutes or so it should cut off... if you cut it off and it is running 30 minutes later.. then there is a problem with the fan relay or temperature sending unit.
Sep 28, 2015 | 2009 Dodge Grand Caravan
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
We moved our LG refrigerator and now it (the motor) keeps turning on but won't stay on
On the LG refrigerators, the cause of this is the main control board failing. It is located on the back of the unit under a small access panel. Here is a link to the part you need.
Oct 15, 2012 | LG LRSC26940ST 36" Side-by-Side...
Panther 110 won't stay running
It might be overheating. Make sure the fan is running. Try raising it up slightly so it can draw more air to cool. Set in on a hard surface.
Apr 03, 2012 | Computers & Internet
HP M7357c overheating problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 03, 2012 | HP m7357c PC Desktop
My Fujitsu Siemens Scaleo P tower fails to boot up, sometimes shuts down after a few seconds, no output to monitor. Can you help My computer works fine untill one morning it shut down with no warning....
pop the CPU, take a closer look athe chip and the socket, make sure there is nothing can create a short of creating any kind of heat. if you don't find anything there, I suggest a new CPU in order.
Apr 17, 2009 | Fujitsu Siemens Computers & Internet
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
