Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn-Air side by side you already answered once!
I hope this is going to docjoh again! Regarding our unit that isn't giving us any water, we checked the tube to see if it was frozen and it doesn't appear to be. We then pulled out the unit, unclamped the water line to see if water was getting to it. Some ugly brown water came out. Could the filter be too dirty and triggered the water off for some reason.? I know that is doubtful, but we haven't changed the filter for a while. There is no light on suggesting that though.
Could the motor be out? No ice is making either. Maytag wants $89 to come out and diagnosis this and with a handy husband, we just want to check everything we can before we spend the money.
We really appreciate your help!
  • 943 Answers
Hi thanks, it could be the water valve at the back of the fridge a fridge with a water dispenser and ice maker has 2 solenoids on 1 valve 4 wires if you don't have a water dispenser just the ice maker then olly 1 solenoid 2 wires you can check by using an old electrical cord install on cord the connectors you see on the valve disconnect the wires that are there now and install cord you just made up disconnect fridge before you do this if the water comes out with this new cord you need a ice maer if it does not. replace the water valve thanks the appliance doc
Posted on Sep 17, 2008
  • john gagnon
    john gagnon Sep 26, 2008
    hi again if you haven't changed your filter i would do that. it helps the water valve stay cleaner thanks
Water does not flow
first you should take the water feed off, clear all water out of tube going to ice maker.remoe ice maker and check the wiring and all looks good.hook water up,turn water on just enough to see you have waterflow yo ice maker.might need a towel or two in the freezer.replace icemaker,make sure bar on ice maker is down,turn water on full,give it 12hrs to make ice. good water flow-no ice--replace ice maker.
Jun 02, 2012 | Jenn-Air JCD2389G Side by Side...
Jennair jsp42ppdbda faulty evaporator drip pan - leaking down into freezer compartment
I've got the same problem. After installing a replacement drip pan (W1019913) and disconnecting the thermistor per the enclosed instructions, the problem returned within two months. I just called Jenn-Air customer service and was told that there is a new design for the drip pan this is only available through Jenn-Air, and not through distributors. Therefore the part I purchased in November through a distributor was the old design (even though it was dated 1/27/11).
The Jenn-Air rep agreed to have a tech install the new design under warranty, even though I purchased the unit almost 5 years ago. I'm hopeful that this will correct the problem.
If you still want instructions on how to remove the drip pan, let me know. But I would return the part you've got and ask Jenn-Air do it for free.
Dec 14, 2011 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air JFC2290v water appears on the floor front right corner, sometimes front left corner as well. I have moved the unit and have not found any water under it. This has been on going for...
I bought the same JFC2290 model and it says "Auto defrost". Mine is only 10 months old and it starts having exactly same problem already. Water leaks and I have to clean my hardwood floor twice a week. I will never own Jen junk again!
Nov 09, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
The jenn-air fridge that i have jcd2289ae has stopped working it is tripping the gfi, i have tried plugging it in another plug in but it trips the breaker here is a simplified wiring diagram for your unit. It might help you track back the problem.
Before it started tripping the circuit breaker what was your refrigerator doing that was not normal? Usually, before something fails massively it will give you hints it is coming. Did your ice maker or lights stop working? Has the compressor been running an excessively long time?
What trips a breaker is the unit drawing more current that what the breaker is listed at. So something in the unit has shorted to cause this to happen. Although the first thing we check in a situation like this is the compressor circuit it isn't always the cause.
Jun 26, 2011 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I have a Jenn Air side by side and the drain at the bottom of the freezer side keeps freezing up and the water ends up draining out the door onto my floor. I defrost the drain and it's ok for a couple...
You are going to have to get the drain good and clean. Take a turkey baser and force hot water down the drain until water flows freely. Once water is flowing freely mix water and baking soda and pour it down the drain. I hope this helps.
Oct 21, 2010 | Jenn-Air JCD2389G Side by Side...
We have a built in Jenn Air refrigerator Model #JS48FSDBDA
Remove the kick plate at the bottom, then you will see the head of a bolt this raises and lowers the wheels, I'm assuming your wheels are up turn bolt clockwise. Thier will be a bolt on each side. The wheels are contained inside of a sheetmetal housing. Once the wheels are down you will be able to roll it back and forth. Go to enter your model # and it will bring up a diagram of your unit. The diagram needed is the one for the cabinet. Hope this helps.
Mar 05, 2010 | Jenn-Air 48" Side-By-Side Built-In...
Water not draining from diswasher
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Nov 03, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
Water collects and freezes in bottom of Kenmore freezer of side-by-side freezer/refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of may see ice build up...melt ice with hair dryer/heat will see a pan below evaporator...melt ice in pan...dry water up in pan with paper you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks!
Jul 15, 2009 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air side by side won't give water
hi thanks for the question yes the small tube that enters the ice maker can freeze up stopping the water flow check this thanks the appliance doc
Sep 16, 2008 | Jenn-Air JCB2280HES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
79 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
