Question about JVC KD-G230 CD Player
Cd stero wiring help
I have a 04 dodge ram I am puting in a JVC deck and all the wiring is matching up except a brown and orange wire the orange wire says illumination. What wires on the JVC wiring side do these connect to.
Thanks Rob
    Brigadier General:
  • 6,966 Answers
To my knowledge, the illumination wire need not be connected to the JVC KD-G230. Further, other than the 8 speaker wires, the JVC has only:
  • black - body ground;
  • yellow - always on B+12
  • red - ACC/IGN B+12
  • blue w/ white stripe - external amp trigger and/or power antenna
Perhaps this might be of further help to you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 17, 2008
Whats the color codes for a 2001 dodge ram 1500 stereo wiring harness?
2001 Dodge Ram 1500 Radio Wire Colors
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Mar 30, 2016 | Dodge Cars & Trucks
Stereo wiring diagram 04 dodge ram 3500
2004 Dodge Ram 2500 Truck Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Jun 11, 2013 | Cars & Trucks
Wiring JVC car deck
Do you have factory infinity sound. If you do you need a another harness or bypass that infinity system. Also What year is the truck. I know for a dodge ram after 02 is a canbus system. When wiring in the harness leave the blue remote wire alone do not connect from radio harness to the harness that connects to factory harness. Unless you are running to an aftermarket amp. There is a brown wire also that you should not connect leave the remote blue and brown wires alone. this is atleast on a 02 dodge 1500 or newer and 03 or newer 2500+. not sure if this will solve your issue but it fixed my buddies.
Apr 29, 2013 | Dodge Cars & Trucks
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Dec 25, 2010 | JVC Car Audio & Video
Wiring harness for 2004 dodge ram 2500. I need to know the wire colors for the rear speakers
Sep 12, 2010 | 2004 Dodge Ram 2500
My dodge wire diagram for an 04 dodge ram does not match the wires in the dash color wise. i have power to the kenwood reciver but no speaker output in the truck only subs and amp have sound
wire diagrams for both your truck and any kenwood deck they will all be the same
or you can find the speakrs unmask them turn them over and look at the wires conneted to them then match them up with the wires you need to connect the cd player harness
Jun 19, 2010 | Kenwood KDC-138 FM / AM Receiver
I am installing a CD player into a 1996 Dodge Ram 2500 Truck and I need the diagram
Here you go:
1996 Dodge Ram 2500 Truck Car Audio Wiring Diagram
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
May 12, 2010 | 1996 Dodge Ram 2500 Club Cab
I have a 2001 Dodge Ram 1500 that I'm trying to up grade my radio form a A and fm cassette to a dual CD cassette . I need help with wiring because they are different colors.I have the new 16 pin harness...
2001 Dodge Ram 1500 Car Radio Wiring Diagram
Sep 09, 2009 | Durabrand Car CD Player and AM/FM...
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
JVC KD-G230 CD Player Logo
350 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
