Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
No sound or pix
Replaced lamp, green lite on for a few secs, then red standby lite , flashes 3 times then pause , then flashes 3 times again, can u help
  • vballer3396 Nov 07, 2008
    Exactly the same problem you just said
  • 10,594 Answers
3 times flash of standby light shows that Lamp Cover is not mounted properly after replacement of Lamp.
Please fix lamp cover properly because cover has to press protection switch in circuit.
Posted on Nov 07, 2008
My kdf-e42a10 tv won't come on flashes green 7 times then flashes red 3 times.
The 3 blinks is lamp door not closed, what it really means is the door may be warped from the heat of the lamp===the door has a plastic peg on the back that when the door is in place engages a lever just behind the door. If the door is even a little bowed=three blinks.
Engage the lever with something not metal and see if set comes on, if it does replace the door.
Apr 08, 2012 | Sony KDF-E42A10 42 in. LCD Television
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Tip
Pix shuts off, green light starts flashing, pix comes back and shuts off again
If you have an issue where your picture turns off and the green power light starts flashing, you are most likely looking at a weak or old lamp. Do not be confused with a pix loss and a RED light flashing, as this can be caused by many things. The normal sequence of events for this fix is this:
1) TV turns on normally, plays for 1 to 3 minutes (may be more or less time)
2) Picture goes out and green power light begins flashing. It may flash for up to 2 minutes
3) green light turns on solid (stops flashing) and picture returns.
4) Picture goes out again and process repeats.
You may have been told that "if the lamp light isn't on, it isn't a bad lamp".
FALSE!
A weak lamp will cause the process above to occur. Other signs of a weak lamp:
The reflector in the lamp is very cloudy
You may see a "growth" or "bubble" on the vertical glass tube which is the lamp
You haven't replaced the lamp in quite some time or it is the original lamp from when you purchased the TV.
In cases like these, try a new lamp. Stick with an original Sony lamp, as there are many stories (both personally witnessed by me and also documented on the web) about problems with after market replacement lamps. And remember, lamps DO NOT have a shelf life; you can store them in a good environment (not too hot or cold!) for an indefinite period with no ill effects.
on Nov 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
Heard a pop. Checked and had to replace the lamp. Now when turned on the power-standby flashes green, then flashes red, but TV never comes on.
How many times red light flashing?
This is an error code and red flashing count indicates a particular problem in specific section of tv, please count how many times red light flashing after 3 seconds long pause and post here to suggest a solution.
Thanks.
May 28, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
My tv comes on runs for 30 sec. then loses sound and picture for 30 sec. and the standby light flashes green for 30 sec. then the picture and sound comes on . then about 30.sec. later it does the whole...
It is symptom of weak lamp that has been reached to an end of its working hours life but not dead/ broke yet.
If lamp has not been replaced in last 2-3 years then please replace lamp in tv to get solve this problem.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for good picture in tv.
Thanks.
Feb 11, 2011 | Sony KDF-E50A10 LCD TV
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
133 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
