Question about Texas Instruments TI-83 Plus Calculator
Y= button does not work
I press the blue y= button and nothing happens the screen goes blank. I really need this function to get by in class, I have to press 2nd(Yellow) to shut it of and then press on to turn it back on something is wrong. Please help.
  • 32 Answers
My guess is that you on have your axes turned off and two that your window is not showing your graph cause it is out of range. You don't need to turn off you calculator. If you can just press clear you should return to the homescreen. So to fix this go to window and put the values as X min:-10 X max:10 ymin:-10 and Ymax:10 then go to 2nd format and turn on x and y axises. and graphing something simple like just y=2 to see if it appears.
Posted on Sep 18, 2008
My acer note book screen has gone blank it sounds like it loading up but the screen then goes black then goes blank with thin lines in screen
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Aug 29, 2011 | Acer Computers & Internet
Turned on the Garmin nuvi 1200. the Garmin logo comes up, loading maps comes up then it goes blank and begins the cycle again. I have held the power button down nothing. I have touched the bottom right of...
Hi! Please try inserting a paperclip on the reset button. Press hold for atleast 15secs. and this can resolve the problem. Hope this helps and thank you for using FixYa!
Oct 16, 2010 | Garmin nuvi 1200 Car GPS Receiver
My psp screen goes blank everytime i press the home button.
this is for the tv out function you can buy a cord so you can play your psp games on your tv and holding down this button activates that but you need the cord eb games have it for about 30 dollars
Jun 03, 2010 | Sony PlayStation Portable (PSP) Console
Press power, buttons light up and thats it
Try pressing the clean cell now button & check pre filter button at the same time hold buttons down at the same time for about 5 seconds with the air cleaner turned of and blue screen lit
Jan 30, 2010 | Kenmore AC2044-1 Air Purifier
Screen went blank
Hi, I experienced the same problem this morning, my sansa player (e280, 8Gb) froze in the middle of a song, the screen went blank but the wheel still had its blue light on and i didn't know how to fix it bur then i figured how. If that's the case with your player too, then the solution will be to press and hold the power button till the blue light goes off (abt 8-10sec) and then just restart the player. It should work.
May 08, 2009 | SanDisk Sansa Fuze MP3 Player
White screen
how do you flash the firmware using pc. can u tell the procedure
Apr 27, 2008 | Nokia 9300 Smartphone
Laptop Screen is Blank
there is a hole on the back usually goldish inside take a pen push it in there hold for a couple seconds and press the power button
Jan 26, 2008 | Toshiba Satellite M35X-S349 Notebook
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
