Question about GE WHRE5260E Top Load Washer
Water sometimes does not shut off. flooded twice. happens intermittently.
  • Anonymous Sep 29, 2008
    i had a flood for same reson.i think drop in water pressure can cause this
  • 1,543 Answers
If when the machine is flooding if you turn off power to the machine and it continues to fill: replace water inlet valve. If flooding water stops filling when power is interupted: clean out the end of the water level switch tube where it connects to the outer wash tub.
Posted on Sep 17, 2008
  • 116 Answers
This suuggest that your water level switch may be blocked/clogged up.
Hot water stops flowing intermittently from tub faucet
Newer tub faucets have a anti-scald feature. It normally looks like a piece of plastic dial just above or below The tub handle. It could be that your water set too hott and he scald valve shuts off the hot water only
Sep 04, 2017 | Plumbing
03 ford focus zx5 2.0l ztec . Happens while driving as well and has died in intersections and on highway but is intermittent . Sometime drives fine then it happens or starts off with it happening high
it looks like it is getting to much gas and flooding the engine. can you smell gas when you get out of the vehicle if so then it is flooded so check your fuel pump
Dec 12, 2012 | Cars & Trucks
I have a 1995 gs 300. The injectors sometimes will add to much fuel n cause the car to shut off n flood. I have to do a flood clear to get it started again. I have had two mechanics run diagnostics but it...
The injectors open and close to feed fuel to cylinders based on data they receive from various censors. If the wrong info is fed to the ecm, this results in the injectors opening too long or too short what ever the case may be. Check out all of the sensors involved in feeding the ecm - Example: if there is a cold start sensor that is not working properly too much fuel will get in there and ......................
Sep 03, 2017 | 1995 Lexus GS 300
Water to the ice maker has flooded the fridge. This has happened twice. Maytag Mod MFI2568AES
OK, water continues to flow into ice maker tray and freezer floor correct? Here is a manual Click here=> MFI2568AES I just need to make sure it is not coming from defrost that may be blocked. Is there water spewing and everywhere? Shut main water supply off ASAP. I will assist you but I need you to answer questions as we move along. There are too many ways this can happen to give you a perfect solution. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services,
Thanks, Sea Breeze
Feb 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
1 unit intermittently shuts off and other won't ignite
if you have the exhaust run together it will not light up,, they have to be seperate,, the computer board sences the unburnt gasses and will not allow it to start,,
Jun 24, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
2001 jeep grand cherokee 4.0 engine shuts off
it is possable/likely a bad ECTS (engine coolant tep. sensor), this can cause the injectors to allow to much fuel into cylinders and cause a low compression and or flooding situation, good luck, marty
Jun 07, 2009 | 2000 Ford Focus
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Dishwasher is not draining and is flooding out the side
It sounds like the float valve is clogged and or you have a timer problem (which is way down on the list of probabilities...very rare...last thing to happen generally ...but not impossible.)....on the floor of the DW is a round Mushroom looking float valve that rises with the water and shuts the water off at a specific time...usually when often gets gunk in it...(soap...debris...etc) and it sticks in the down...too much water...or in the water....position...take it off...just lift up...and listen for a clicking noise...check to see if it is clean...if not clean it and replace it...push it up and down listening for the clicking noise...if you don't hear one...then it may not be making contact with the contactor...check to see that it does...and it it is and no contact noise with movement replace the contact.
Also some DW's have a sump (drain ) area where water collects to drain...sometimes debris collects in this area....and inhibits drainage...check to see that no debris (careful could be broken glass) is inhibiting drainage.
Hope this helps....and good luck...let me know if it does not... thanks for rating my effort...The Fang.
May 19, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
My maytag neptune sometimes fills with water and floods my floor
It sounds like the water valve is starting to go. i would get a tech out just to make sure.
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
16 year old whirlpool dishwasher model no. DU8950XY-0
Sounds like it is a bad door seal. Recommend replacing the door seal and making sure the door is shutting square and not bent.
Jun 25, 2017 | Whirlpool Dishwashers
GE WHRE5260E Top Load Washer Logo
233 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
