Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
No manual Hi there my bissell will not **** up the water its been some time ago that I used it and it has not been used more than 2or 3 times can any one help me with this. I have also miss placed my manual and instruction this does not help me either .So if any one can help Id be a happy woman with clean floors thanx Vickie
  • Track Chick Oct 05, 2008
    The machine will dispense water but will not **** it back up
  • Anonymous Oct 13, 2008
    my vacuum does not take up water.
  • 4 Answers
Link to the manual download - http://www.bissell.com/Product_Search.aspx?Criteria=1699
CHeck to see if the front of the unit is clogged with hair (espically if you have a dog or cat) also check on the fill tank if the red filter is clogged. An easy test to make sure you unit is working is to turn it on with out the fill tank in it. CHeck for suction on the right side (if you are standing behind the unit) IF not you either have blockage somewhere or the pump is not working.
Posted on Oct 06, 2008
I am not gettng vacuum above 30 torr
Posted on Sep 17, 2008
  • chavhan_amol Sep 17, 2008
    i am having problem , not getting vacuum above 30 torr though my system is design on 2 torr & there is no lekage found all parameter (9 kg steam water is 2 kg/sq.cm)
I have a Bissel Pro Heat Plus and I used it once, one year ago. I may be using it wrong, as my carpets were wet and there was no return (dirty water). If I remember correctly, going forward wets and...
It has only one tank that serves two purposes. It holds the clean water and collects the dirty water, so you only have to empty/fill one tank. If you check reviews of this machine you will see that they basically stop working correctly after a very short time, if I was you I would just contact their customer service at this number 1-800-237-7691
May 16, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell will not spray out water or soap. I checked the belt and it is not broken. bissell is only 6 months old and i have only used it 3 times. can you help me
it could be the water pump blocked up or the jet with old sope,,,its best to flush them through with clean water before you put them away after use,,,
Aug 09, 2010 | Vacuums
Bissell 8920 wont spray any water/ solution except when in water
It sounds like you have a clogged line, if your mechanically inclined you can fix this yourself by tearing the unit apart. If you open the unit up, disconnect the lines on your pump and blow an air compressor through them. certain lines require you to press the switch at the same time as blowing the air through them. If you have the receipt contact bissell and they will refer you to the local warranty center
Aug 29, 2009 | Bissell 8910 ProHeat Clear View Upright...
No water spraying out
go to bissell.com. under feq askes questions. Also speak to or e-mal someonee from customer service.
Jul 22, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
