Question about Juki MO-655 Mechanical Sewing Machine
I need help threading my Juki TL98Q - Juki MO-655 Mechanical Sewing Machine
  • 323 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Sep 19, 2008
Changing needle on juki tl98q
Push needle all the way up into needle bar shaft, flat side toward back. Firmly tighten screw to secure needle. Jimmy
Apr 09, 2012 | Juki TL-98Q
Juki owners manua for Tl 98q
Learn how by downloading the Users Guide from the link below.
http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf
Hope this helps.Thanks!
Ken.
Jan 11, 2012 | Sewing Machines
I have a juki tl98q sewing machine for my mid arm. The bottom thread keeps bunching up and I cannot sew anymore. What can I do to fix this? Do you have a diagram to thread the bottom bobbin and the top of...
The threading diagrams are available in the manual which is available from Juki on the TL-98Q product page: http://www.juki.co.jp/household_en/pism/tl98q.html . The direct link to the manual is http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf . See pages 14-18 (pages 16-21 of the PDF).
There are a couple of things I recommend that you check. First, make sure that the bobbin is evenly wound. This is a function of the bobbin winder tension; see the manual (page 15) for that adjustment. Next, check if the bobbin case tension is correct. Place the bobbin in the bobbin case and dangle the unit from the thread. Try to shake the bobbin case up and down, sort of like a yo-yo. The thread should advance by a bit. If the thread length doesn't change, loosen the set screw on the side of the bobbin case a small amount. If you get a really long tail of thread, tighten the set screw. See page 21 of the manual.
Next check for any loose threads and dirt in the housing around the bobbin case. Depending on the length of time that you have been using the needle, replace the needle.
I hope this helps.
Sep 28, 2017 | Juki TL-98Q
I have started quilting a large quilt and having problems with the bottom thread showing through at the hole puncture. My backing is purple and the bottom thread matches the purple color. My top is made...
Use a universal #10 needle. The smaller the hole from the needle the less you will see of the bottom thread showing on the top. And I'm sure your using good quality #50 weight cottom thread, right?
May 12, 2011 | Juki Sewing Machines
I need User Manual for Juki TL98E
hi there
i had JUKI TL98Q if same email me i can send to you service manual by mail
best regards
ashraf abozid
aabozid@hotmail.com
Aug 17, 2010 | Juki Sewing Machines
I have lost the manual and i dont remember how to thread a bobbin. Pleas help me and thank you!
Juki TL-98Q
Loading the bobbin into the bobbin case:
Snap in the bobbin case latch, and put the bobbin into the bobbin case so that the bobbin runs clockwise.
Passing the thread through the **** of the bobbin case, continue passing it under the thread tension spring, and pull out the thread open end about 10 cm from the bobbin case.
Insert the bobbin case fully into the hook, and close the bobbin case latch.
You can obtain a copy of the manual in pdf format for free at:
Jul 29, 2010 | Juki TL-98Q
My juki tl98q foot pedal and thread cutter has stopped working. help
Check the power cord and then take apart the side door and check the thread cutter for any displaced working machanisms. OK!!
Nov 28, 2009 | Juki TL-98Q
Juki TL98Q needle thread breakage
your bobbin it is not in his right position, quit tightin your tension.
Sep 29, 2009 | Juki TL-98Q
Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Jan 18, 2009 | Juki TL-98Q
Juki MO-655 Mechanical Sewing Machine Logo
142 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
