Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Dark picture My tv has gotten very dark. I used the vivid setting on this tv and loved the picture I got. The picture now is not as bright and on some shows it gets so dark i cant see at all. I have tried adjusting the brightness contrast and color and nothing has worked. Dvd's look great on it. Any ideas on what may be wrong? I have a dark picture on all channels, I tried to adjust everything but nothing works. My TV is about 5 years old.
    Problem Solver:
You know it sounds like the same problem i had....
look this is something you can try.... "turn the tv off and unplugg it!!!"...you'll need to take out the lower front part of the tv......(where the speakers are to be exact) on each lower end you will find 2 screws..Be careful it will open to the side and there are many wires, i suggest you mark them to know where to put them back...then right in the middle there will be a black cover with about 5 screws..take them out....and look at the very bottom you'll see a thing with 6 pegs....the top ones are for the screen "DO NOT TOUCH THEM"...the ones on the bottom are for the colors...re adjust them...the left one it's for blue, the middle one it's for green and the last one it's for red...
I had the same problem after i moved....and after i re adjust that the tv looks super...
i hope that helps..:P
Posted on Oct 29, 2008
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: dark picture
sony had a recall on this set see if this is one of yours
http://esupport.sony.com/perl/news-item.pl?news_id=24
Posted on Jan 02, 2008
The best contrast and brightness settings for a toshiba crt floor model tv,model 50A61
Televisions are unlike other consumer electronics products. Their setup and settings have a tremendous effect on how well they perform. The best TV on the market incorrectly setup will almost always look worse than a mediocre TV setup well.
Ideally, you'll get a setup disc to ensure the correct settings, but regardless, it's important to know what each setting actually does.
To get the ultimate performance out of your TV, a full calibration by an ISF Certified technician is your best option. Even if you go that route, it's good to know what the calibrator is adjusting. So here's a quick look at the basic settings every TV has, and what they do.
Please keep in mind, this is only a general guide in what each setting does, and rough idea how to set it. Correctly setting up a television is a completely different article.
Where to start
Nearly all modern TVs have picture modes. These are labeled things like Standard, Cinema, Vivid, and so on. Cinema or Movie is often the most accurate setting, with all the controls set to offer an image close to what a director intended them to look like. Most people aren't used to an accurate image like this, and to them the TV may appear reddish, soft, and possibly dim. Technically, it isn't. Other picture modes like Vivid or Dynamic are programmed to "pop" on a store sales floor with an overenhanced, blue image. Because most people don't change any of their TV's settings, this has resulted in most people thinking a TV should look blue.
The choice is yours, of course, but we here prefer an accurate image and suggest you at least try it for a few days. Once you get used to it, you'll never go back. Check out What's the best picture mode? for more info.
Regardless, all TVs need tweaking to look their best. Here's what the main controls do.
Backlight
Only LCDs have this control (though not all of them). This is a direct control of how bright the image is. Setting this lower will reduce eyestrain, and save a little on electricity. Before you adjust Contrast to make the image brighter, try here first. Check out LED LCD backlights explained for more on this.
Some plasmas have a control that drives the pixels harder, which in some ways acts similar to a backlight control. Samsung's name for this on their plasmas is Cell Light.
Contrast
Sometimes labeled "Picture." This control makes the image brighter...up to a point. Every television has a maximum light output. Once you reach this point, increasing the Contrast control further actually degrades the image. Correctly set, you would see a fluffy cloud in a bright sky. Set too high, you'd see a blotch of white instead. As mentioned above, try setting the overall light output of an LCD with the Backlight control first (if available). Then adjust the Contrast.
Brightness
This controls how dark the dark areas of the image are, again, to a point. Every TV has a minimum light output. Once you reach this point, decreasing the Brightness control starts removing "shadow detail." Correctly set, you'd see all the detail in a black leather jacket at night. Set too low, and it would be a black area on a black area, probably with a head sticking out of it. For more information on how the contrast, brightness and backlight settings interact, check out my article on contrast ratio.
Color
Can be thought of as color saturation. Setting this too high will make everything look cartoony. Setting it too low will make for an expensive black-and-white HDTV.
Tint
Rarely will you need to adjust tint, a vestigial control left over from the CRT "tube" TV days. It gives a green or magenta shade to the image.
Jun 23, 2016 | Toshiba Televison & Video
Dark picture
Please check your TV's Picture mode setting. Use the VIVID picture mode to achieve the brightness video.
Mar 11, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Whats the best picture settings for 42 lcd insignia tv
Hello
55% Contrast, 35% Color and brightness to match will give you a vivid picture to your TV.
Mar 05, 2012 | Insignia 42" LCD Flat-Panel HDTV
My sony 42 inch seem to be dark always i have the bright at 85% and it still dark
It can be corrected by some adjustments at the video set up found at the settings menu. Just by pressing menu button on your remote commander, then go to settings then select video set up and press enter then select vivid or normal by pressing the enter button. this will automatically set your unit to vivid or normal mode.
Oct 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Samsung DLP HD tv's picture is starting to go dim. What can I do to make the picture bright like it used to be. Model Code - HLS6187WX Thank you for any help you can provide. Spencer
Has the lamp ever been replaced? As lamps age they get darker screens. First though check to make sure the TV settings aren't accidentally on a dark setting. Go into the menu and see if increasing the brightness helps.Different picture modes like movie, games, vivid have different brightness settings vivid usually the brightest.
Sep 11, 2010 | Samsung Televison & Video
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Best tv settings for samsung LE40A457
Best is kind of subjective since each person's eyes are different. If you are looking for a bright and vivid picture, you can go to the picture mode and change it to that setting. Usually it is called something like "Vivid" or "Dynamic." Besides that, it is all user preference. Most people prefer to just use the factory default settings.
Nov 09, 2009 | Samsung LE40M91B 40 in. LCD TV
Dark picture
Oct 01, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
147 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
