Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Kenmore Elite Washer top load
During spin rocks back and forth hard and load is NOT off balance.
It bangs hard!!!! Is this the basket support worn out? What else could it be. Please send diagram if you have one
  • Anonymous Mar 19, 2014
    thumping, banging, out of balance
  • 116 Answers
One or two of your suspension spring may be broken
Regards
Posted on Sep 20, 2008
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
My Kenmore Elite Oasis top load washer will start when is ready. We press the start button several times and hold it down for minutes at a time then maybe it will start. Plus even the smallest load will be...
If the washer is shaking and actually going out of balance and generating the UL error and the drum is empty the most likely cause of this problem is something under the spin basket.Clothes can end up under the spin basket and cause it to turn crocked and cause the out of balance. First I'd recommend removing the spin basket and check under it for any clothing or other obstruction that might cause the out of balance. Here is a diagram of how to Check.. Click Here
May 22, 2011 | Kenmore Washing Machines
My kenmore elite top loader has a loud banging noise when spinning
Disconnect power to the washer then tape the lid closed. Lay the washer carefully on its front panel on a padded surface then check the four suspension spring/rod assembly. Make sure the suspension doors are properly attached to the outer tub to prevent an off balance situation that may lead to the banging of the basket to the outer tub during the spin cycle. Also ensure the machine is balanced and properly or evenly seated on the floor.
May 07, 2010 | Washing Machines
My washer is perfectly level but during the spin
if you can make it rock by hand or by jumping the legs are not adjusted proper.it can also rock if the floor is soft... then get thick plywood under the washer ....11/2 inch should be good.you should try to balance the load put heavy things in first
Aug 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Thumping and banging
    make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
    Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore washing machine out of balance when spinning, bangs and grinds, when still drum out of balance can be viewed out of balance. Wahing machine heavy duty model C1184514080
    Sounds to me like you have a worn drive block and possibly a bad spin tube. The drive block can be accessed by removing the agitator first. Next you will need to remove the spanner nut. Now you can remove the basket. Attached you will see the picture of the drive block, I hope if it downloads. The spin tube locks into this drive block with two tabs that fit in respective grooves in the block. If the tabs are worn off the spin tube, that will have to be replaced as well. Good luck,
    May 17, 2006 | Kenmore 24872 Top Load Washer
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    137 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
