Question about Sharp Office Equipment & Supplies
Sharp AR-M205 Calling for Maintenance. How do yuo reset?
  • John Falez Sep 17, 2008
    Sharp multifunction AR-M205 is calling for maintenance. This would be ascheduled service and required a PM kit. What is in the PM kit and how do you access service to reset the service alert?
    Brigadier General:
  • 6,966 Answers
It would seem that you simply want to bypass the "Maintenance" display without calling for service. To do so, pls try:
  • For AR-M205 Press "#" - "Interrupt" - "Clear" - "Interrupt". Machine will blank off;
  • Use quantity buttons to make display read "20". Press "Start" button. Machine will flash 00;
  • Use quantity buttons to make display read "01". Press "Start" button. Machine will flash 000;
  • Press "Clear" - "Clear" - "Clear" - "Clear" and power machine off and back on.
Perform this procedure at you own risk. Incorrect entry of codes can disable machine requiring service call.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 17, 2008
    Master:
  • 441 Answers
AR-M205 - Trouble Reset
Press: "#", "Interupt", "Clear", "Interupt", "14", "Start Key"
AR-M205 - Drum Counter Reset
Press: "#", "Interupt", "Clear", "Interupt", "24", "Start Key", "7", "Start Key"
    Genius:
  • 1,550 Answers
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button , the printer will move into a service mode. (Waiting for menu selection)
  • When the LED lights in green, press the Stop/Reset button 4 time
    Sergeant:
  • 300 Answers
1. unplug the printers power cable it resets ALL printers
2. Once you have it unplug the power cable back in and turn it on make sure it's plugged into the computer.
3. you may need to uninstall and reinstall any software and drivers that came with the printer
4. download and install all the critical updates and service packs for your operating system
5. download and install any updates for your printer from the shap printer driver site
Az.
What to do when Sharp AR-M205 showing message h4
Fusing error.
check fuser unit first and reset by simulation 14.
Mar 11, 2014 | Sharp AR-M205 Copier
How do I reset the Sharp AR-M205 Copier please?
On the key pad P * C * sim 14
pound star clear star sim 14
Aug 24, 2010 | Sharp AR-M205 Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
I have a sharp AR-m205 with a flasing l6-10 erro message. Can the machine be reset?
Hello sir; the code you display,can not be reset, the problem of it, is laser motor bad you need to replace one.
Jun 11, 2009 | Sharp AR-M205 Copier
My Sharp AR M205 has the error H4
Hello sir; Your machine require reset procedure; press "#", "interupt", "clear", "interupt" then enter 14 press start.
Jun 04, 2009 | Sharp AR-M205 Black and White Copier
Sharp AR-M205 is not working with windows vista home edition
1. Uninstall the previous driver
2. Re-install the driver ( do not connect the usb cable at this time )
3. After driver installation, the pc will ask you to connect the usb, do this and it should be OK
Apr 01, 2009 | Sharp AR-M205 Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
System settings on Sharp AR-M205
Found a very good solution...Use Adobe Acrobat to do the scanning. Launch Adobe Acrobat and select the AR-M205 as your scanner and proced from there. Adobe will pull up the Sharpe software to do the actual scanning but Adobe will be in charge and create a pdf file. I am using Adobe 6.0 which is not one of the free versions, I think.
Dec 18, 2008 | Sharp AR-M205 Copier
373 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
