Question about Refrigerators
Kitchen Aid fridge Mod# KSRS25ILSS02
Not cooling on fridge side, freezer side o.k.
  • 2 more comments
  • Jerry Kerns Sep 17, 2008
    Fans are working, no obstructions
    Well now the freezer side is not cooling
    cut power, reconnected after 1 hr. motor runs,fan runs, lights work, not cooling.
    Thank you for your help
    Brigadier General:
  • 6,966 Answers
Initially, pls try to verify if the blower fan is working. Its function is to draw cold air from the freezer side and vent it to the fridge side. Additionally, pls check if the air pathway is block or obstructed. Pls post back results of checks.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 17, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Sep 17, 2008
    Hi again and appreciate the quick update.
    I understand fans are working and no obstructions, sorry and pls bear with me is the airflow strong?
  • Louie  Role
    A common failure with this series/models is the Air diffuser assembly, often, this diffusers tend to be stuck in the closed position (or partially closed) prevent sufficient cold air from the freezer to blow to the refrigerator area.
    Additional insights may be sourced from here.
  • Louie  Role
    Again appreciate the update.
    This is a completely different problem. Initially a couple of possibilities:
    • faulty thermostat;
    • faulty compressor;
    • refrigerant leak;
    • stuck in defrost mode.
    Things to check:
    • does the motor at least run?
    • does the interior light works?
    Initially, pls try:
    • unplug from the mains for at least an hour. This of course would mean that food stuff and other perishable items should be temporarily moved to another cold storage/fridge.
  • Louie  Role
    If the motor runs, the compressor should be pumping the refrigerant around the system. If even the freezer is not cooling, possibly:
    refrigerant leak;
    clogged tubes (condenser/evaporator);
    compressor problem.
    Unfortunately you would need an onsite qualified professional to determine above stated possible problem.
Kitchen aid bottom freezer fridge. The freezer part is cool but does not freeze.
Maybe lossing gas slowly have your tech confirm this for you.
Jan 14, 2016 | Refrigerators
My freezer is too cold
There should be a freezer and a fridge side temperature setting , look for both is fridge side
Oct 05, 2014 | KitchenAid Kitchen Aid - KSC23C8EYY...
My kitchen aid refrigerator is not cooling like it use to, the freezer side is ice cold but the fridge side is almost at room temp, i have a feeling its the thingy in between the freezer and fridge at the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | KitchenAid KSRS25IL Side by Side...
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Fridge problem
ok first the freezer does all the cooling for the whole unit and in order for it to cool properly the freezer needs to be a certain temp it should be around -10 -6 if its not reaching that temp it will still freeze and apper to be working right also check to hear if the freezer fan is running as it pulls air from the fridge and cools it then blowes it back look in the freezer on the back wall toward the bottom see if frost is building also in the refridgerator section on the left hand side of the cabnit is a return vent make sure its not blocked and see what the thermostat in the freezer is and let me know we need to know things like this to help narrow the promblems and people dont reply to the questions so we cant answer appliance repair is a skill
Jul 13, 2008 | Refrigerators
Kitchen Aid side by side referigerator KSSC42QMSO
the freezer does all the cooling for both sides a few shelves down in the fridge on the left hand side there is an air intake make sure nothing is blocking it also listen for the freezer fan to run if its not look at the coils in the bottom of the freezer to see if they are heavly frosted in the fridge side at the top left side should be some vents hold your hand there to see if air is blowing through if not reply to me well go from there
Nov 29, 2007 | KitchenAid KSRP22FNSS Side by Side...
Kitchen Aid Fridge
how long does it take for fridge to cool if its not been used in months?
Nov 23, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Stinky Ice
You could try using ice aid, http://www.partadvantage.com/store/showpart/10127281. However there is nothing on a fridge that causes an odor only things that are put into the fridge i.e. food, water quality.
Nov 07, 2007 | Refrigerators
Refrigerators Logo
263 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
