Question about Krups XP4030 Espresso Machine
Krups XP4030 Steamer won't steam
The brewing process for my XP4030 works great, however, after switching to the steamer (and waiting the allotted amount of time,) I would turn it to the steaming function but all I get is a weak, weak drip.
I have done two descalings trying to fix the problem but there is no improvement.
It would seem that there isn't any proper gathering of steam, or the steam will not reach the steamer itself.
  • 1 more comment
  • Anonymous Nov 27, 2008
    Can't get a good steam!  Have  had better luck steaming with cheaper steam models!
  • Anonymous Jan 21, 2009
    My steam is the same a weak drip but alot of steam build up int he machine.
  • PeteNPA Apr 06, 2009
    This started happening a month after we got it... returned it and got a new one. Only used it a dozen times or so in 11 months and started happening again. I didn't have the reciept so they wouldn't fix it AGAIN. Basically useless for steaming... wont buy another Krups again.
SOURCE: Krups XP4030 is stuck in the steaming mode
Here is a link for the manual. It says on Krups web sight they have a 1 year warranty,
http://www.krupsonlinestore.com/manual/55360.pdf
Posted on Jan 10, 2008
  • 123 Answers
SOURCE: Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Posted on Apr 11, 2008
  • 74 Answers
SOURCE: saeco odea steamer is leaking
its the casket in the Tpipe that has gone bad.
Posted on Jul 11, 2008
SOURCE: Dualit espresso machine
lost my instructions for descaling my delonghi espresso machine
Posted on Mar 02, 2009
EsWorld
  • 1618 Answers
SOURCE: Espresso brews too fast on Krups XP4030
Check/adjust the grind on your coffee.
Posted on Jun 24, 2009
The milk steamer is not frothing. I have tried cleaning and descaling
If it does not produce steam when you switch to steam mode and wait for it to heat up, the steam thermostat needs to be replaced.
Mar 03, 2011 | Krups Espresso Novo 2100
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
My milk steamer is no longer steaming. Some steam comes out but not enough to steam the milk. The expresso part is working fine as I recently used a Krups descaling kit on it.
From your message that it is clear that the steam is coming but it is not sufficient to heat the milk, so kindly call the customer care to sort the problem as you can't do it
Thank you.
May 08, 2010 | Krups XP4030 Espresso Machine
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
Steam Nozzle
I've only had it fly off once.  I think I didn't put it all the way on.  Also make sure you clean the nozzle every time you use the steamer.  Milk will clog the nozzle otherwise.  My maker is right beside the sink and I rinse the nozzle immediately after steaming milk.  I also run it through the dishwasher at least weekly.  (This isn't a substitute for immediate clearing of the nozzle.)   A clogged nozzle will always blow off the end.
Aug 12, 2008 | Krups XP4030 Espresso Machine
Hi, we have a Krups espresso machine, model fnd1. We can't seem to make the milk steamer work, it will make the milk REALLY hot, but not foamy. Do you replenish the steam supply somewhere? Is there a...
suggestions include very cold milk.  having the nozzle just barely in for frothing.
On my model there's an air passage in the nozzle that foams quite nicely.  If you have that too, it might be clogged with milk.  You have to keep these clean with every use.
Jul 11, 2008 | Krups XP4030 Espresso Machine
Steam frother
1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for the machine for an hour. 4. Remove sheath from the steamer. 5. Place tip of steamer into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through steamer.
Optional: Before starting the process, unbend a paperclip or metal hook (for hanging holiday ornaments) and use it to clear the steamer orifice.
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Jun 19, 2008 | Krups Allegro FND111 Espresso & Coffee...
Would you return this PS200 steamer?
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Jun 13, 2008 | Homedics PS-200 Iron with Auto Shut-off
Apr 11, 2008 | Coffee Makers & Espresso Machines
Nov 02, 2007 | Krups XP4030 Espresso Machine
Krups XP4030 Espresso Machine Logo
184 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
