Check for a lose connection at the brake master cylinder , There is fluid level sensor on the side of master cylinder !
Brake Warning System Description and Operation
Brake System Indicator
The IPC illuminates the brake indicator when the following occurs:
The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination. If the vehicle is shifted out of park with the park brake engaged, the BCM activates an audible warning.
The body control module (BCM) detects a low brake fluid condition (signal circuit is low). The IPC receives a class 2 message from the BCM requesting illumination.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
Brake light is controlled by a switch on the brake pedal arm. The switch needs adjustment or be replaced.
Hope this helps.
Check your fluid level
