Question about Intertherm Heating & Cooling
I have an Intertherm Baseboard Heater, 7 ft long. Model # B OO1830042. - Model EP 1500-12 Volts 120 Watts 1500 12.5 Amps 120-1500-EP/83NV1-6 Issue # D-17242. I need a new Thermostat- Control for this unit. Cost details, shipping etc. Also, Is a new Face panel available for same?
2 Suggested Answers
  • 3 Answers
SOURCE: How many BTUs does this unit have?
The M3X05F2A is a 5000 BTU unit.
Posted on Jun 16, 2009
Can you use a plug in timer to switch your storage heater on during the cheap rate electricity
Generally NO.
But...it Depends on amp rating of timer, wattage of water heater, and line voltage.
Look at label on side of heater for watts.
Electric water heater will work on any voltage.
1) Start with 120 Volt outlet::
Volts x amps = watts
Watts divided by volts = amps
Let's say outlet is 120Volts. Lets say water heater is rated 4500 watts.
4500 divided by 120 = 37 amps
There is NO plug-in timer rated for 37 amps.
Let's say water heater is rated 900 watts.
900 divided by 120 volts = 7.5 amps
Yes. The Intermatic HB113 timer will handle up to 8 amps.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
2) 240 Volt outlet
Same calculations as above.
1900 watt element divided by 240 volts = 8 amp.
Yes, the Intermatic HB112 timer will safely handle that element.
3) Here are some water heater timers:
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
4) Here are some off-peak water heater ideas.
http://waterheatertimer.org/Off-peak-water-heater-ideas.html
Oct 31, 2012 | Hardware & Accessories
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
I need to fix the on off switch on a Honeywell portable baseboard heater
Go to lowes or home depot and buy a properly rated switch and install it. Make sure to check the device and get its watts, amps and or volts before you go as they will want at least 2 of those items. Watts and amps or volts and watts or amps and volts.
Jan 27, 2011 | Honeywell Heating & Cooling
I have a trailer house that has a 100 amp breaker box in it. I has gas for heat, water heater and stove. I am changing them to electric. Will I need to change the panel put to a 200 amp.
Its probably not a bad idea. Thats alot for a 100A panel to handle, a range needs a 50A, a water heater needs 30A, and the heat will need a 50A or a 60A breaker... Plus whatever else is in the house will be a bit more than the 100A service can handle. But if you don't have the money it will do for a while because for the most part they won't all be pulling at the same time. Word to the wise get at least a 30 space panel when you upgrade, I always install a 40 space panel because for the cost difference its well worth it for future needs because you'll fill it up quicker than you think and you'll have space for anything else you may want to add later on. Hope I helped
Dec 09, 2010 | Your One Source Homeline Circuit Breaker
What is the recommended circuit breaker for a 220 volt connection to a 6' baseboard heater
depends upon wattage of baseboard. I would guess about 20 -30 amps. Amps = Watts/Volts. Example, 1500 watts/220 volts = breaker size of 6.8 amps (add 25%) The only breaker available is a 15 amp breaker.
Oct 05, 2010 | Heating & Cooling
I have a FahrenheatPro. and it doesn't seems to not throw out hea
the baseboard heaters out put goes down a lot more than you would think when used on 120 volts ... thats because not only is the voltage half of what it should be, the current is also half .. so the total power (the product of voltage and current) is one fourth of what it would be if operated on 240 volts .. you are operating at only 186 watts instead of the 750 watts you should have .. so you would have to have 4 times as many heaters for the same heat output .. you likely have the 240 volts available (most houses do) .. there are two phases .. each 120 volts .. when both phases are used together then you get the 240 volts total .. another option is you can use heaters designed for 120 volts .. the current would increase to a little more than 6 amps per heater .. some heaters have a jumper you can move for 120 volt service or 240 volt service... you can use those with either voltage ..
Sep 12, 2009 | Fahrenheat Electric Convector Baseboard...
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to size a room for baseboard.
HERE YOU GO CALCULATE THE HEAT @ 10 WATTS PER SQUARE FOOT , TAKE THE LENGTH X WIDTH X 10 AND THIS WILL TELL YOU THE AMOUNT OF WATTAGE YOU NEED . MOST ALL BASEBOARD HEATERS ARE RATED @ 250 WATTS PER LEN FT AS TO SAY A EX. A 4FT HEATER IS 1000 WATTS , MOST OF THE THERMOSTATS ARE RATED @ 20 AMPS AS IS THE 12-2-WG WIRE TO RUN TO HEATERS AND THERMOSTAT DIVIDE THE TOTAL WATTAGE BY THE LINE VOLTAGE USUALLY 240VOLT IN US .AND THIS WILL TELL YOU THE CURRENT DRAW ----WHICH CANNOT EXCEED 20 AMPS ON 12-3-WG AND THAT IS THE LIMIT OF THE THERMOSTAT AS WELL THESE STATES APPLY 99% OF THE TIME I DO REALIZE THERE ARE EX BUT HAVE USED THESE FORMULAS FOR 35 YEARS OF DOING MY WORK AND THEY DO FINE
Dec 16, 2008 | Fahrenheat Electric Convector Baseboard...
Basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Oct 25, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
200 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
