Question about Dryers
My kenwood dryer
My dryer dont heat up anymoe what do i need to do to get the heat back..
    Genius:
  • 2,920 Answers
Check the heating element and limit switches
Posted on Sep 17, 2008
Kenwood KCD1W tumble dryer not heating up replaced element and all three stats still not getting hot ?
Check main cable connections and power from main circuit. Possible one leg is open because of circuit breaker defective, open circuit from breaker through connection on the back of the drier. Sometimes the connector internal at the power connection will fail (see second image).
Check Thermo-fuse. If this thermo-fuse fails it will need to be replaced. (see first image).
If only one leg that supplies 120 volts is powered then motor and controls can operate. the heater elements are the part of the dryer that requires the other leg for the 240.
Hope this helps?
Nov 29, 2016 | Dryers
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
Kenwood 400 tumbles but not heating.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 07, 2011 | Dryers
Heat doesn't work. It is a gaz kenwood dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 05, 2011 | Kenmore Dryers
Dryer functions but no heat; only cool air
unplug dryer and gain axcess to back of dryer and remove back wall plate look at lint shute bulkhead housing their will be one thermostat with four wires and one white plastic fuse safely remove the wires off fuse and tape together for testing only ...... make sure cover with electrical tape now make sure wires dont touch anything meatal no plug in dryer and check for heat if dryer starts heating goahead and order new fuse and replace thermal fuse ,,, and clean dryer venting and check for any kinks in vent pipe ........ if that test didnt produce any heat replace heating element its in aluminum duct on right side of the back of dryer ...... their is also a high limit tstat on the upper left side of this duct you can jump this out for testing only and check for heat aswell donot operate dryer with these jumped out except for testing theses are safety precautionary thermostats,,,
Jan 28, 2011 | Whirlpool LER4634J Electric Dryer
The dryer dont heat
What is the make and model of your dryer?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Dec 28, 2010 | Kenmore Dryers
My front load dryer model number FEQ1442ESO is running but i dont have any heat. do you know what could be wrong
an internal thermostat called a snapstat and/or your heating element and/or your dryer ventmay not be working or needs cleaning. you need someone experienced in testing with an ohmmeter to test and get back to us.thanks karl
Dec 02, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Kenwood dryer not heating up
my dryer is not getting hot what do i do
Aug 19, 2008 | Dryers
Kenwood
replace both 30 amp fuses in you fuse box and try that.
Dec 23, 2007 | Dryers
Dryers Logo
193 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
