Question about Whirlpool Duet GHW9150P Front Load Washer
Sud flashing on whirlpool duet front load - Whirlpool Duet GHW9150P Front Load Washer
  • Anonymous Mar 17, 2014
    SUD error
  • 5,911 Answers
The following link explains the "SUD" error:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
Read through the link thoroughly. If you are using the correct detergent at the correct amount, make sure it is not a brand that is concentrated. If you need to access the drain pump to inspect it for obstructions, the following link applies:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I hope you find this information helpful. If you perfom all these actions and still have a problem, please post back and let me know if I can assist you further.
Posted on Sep 17, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
SOURCE: Suds and F35 keep shuting down my laundry day:(
I followed the suggestions of opening the lower panel and checking the filter. I found it completely clean but the machine still gave me the SUD code .... so, I detached the hose and blew it out. There was nothing more than still water in it but after running water through it and reinstalling it, the machine work fine once again.
Posted on Jul 17, 2011
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
jsrock516
  • 5911 Answers
SOURCE: whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 28, 2009
Whrilpool front load washer keeps flashing f 02, how do i fix this
SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet front load wash machine- it keeps freezing up and flashes the word sud
this is what the code book says that could be you problem. Overdose of detergent detected during the wash cycle. this may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If to much soap was used run the unit through a rinse/spin cycle than a normal cycle without add any soap. this should clear the unit of the excess soap.
check the drain hose and make sure it is not plugged or kinked.
check wire harness connections to the drain pump,pressure switch, and central control unit.
check/ clean drain pump filter of foreign objects.
check drain pump
check the pressure switch
check CCU.
Replace failed component. Hope this helps
Nov 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer flases F and sud and will not drain
your using to much soap front loaders use 2 table spoons of soap and maker sure it's HE soap
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing sud then f21 ????????
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
4,455 people viewed this question
Dan Webster
Dan Webster
prem mathew
