Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus Built-In Dishwasher
Dishwasher operates fine, but makes a loud humming noise while operating.
  • cstuhr5 Sep 25, 2008
    It seems to being washing well, but the last couple of washings have been really loud. It sounds like it is grinding/vibrating in the lower portion of the unit. I thought my son was playing with his electric toothbrush in the kitchen. We just bought this house and we don't have the owners manual for the washer. What do you suggest? It can't be more than 5 years old. (age of house).
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Posted on Oct 04, 2008
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
My dishwasher is making funny noise and leaves
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jun 13, 2010 | GE Nautilus 24" Built-in Dishwasher
My dishwasher is making a very loud rumbling noise at certain times during the wash cycle. it's a ge nautilus
That usually comes from the main wash head being reinstalled without the white washer which provides a smooth surface for it to glide on, or it has cracked and fallen off, OR it's mounter to the head and has simply eroded.
Mar 11, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus making noise
hi you have something in the sump there's a screen on the right side of the spray arm with 2 screws remove them and take screen off use your fingers to probe the cavity be careful it could be glass.
If it does not correct the problem
!.You may have an electric pump . and it could be pump without water . so i would say a bad pump.
I hope this helps...I believe it will....Good luck and good day....thank you for your rating my effort....The Fang.
Mar 23, 2009 | GE Nautilus 24" Built-in Dishwasher
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Nautilius not running
drain motor doesn't work, yo cn hear a little noise but maybe to hot, th motor doesn't turn.
Jun 29, 2008 | GE Nautilus 24" Built-in Dishwasher
GE NAUTILUS DISHWASHER
The pump motor may be stuck. If this is the case, as it often is with a GE dishwasher, you can break it loose (e.g. spin the impeller until it doesn't spring back any more). If it's not stuck, it may have something inside of the pump motor and it may need to be replaced.
Mar 25, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus ...
Does water drains out properly ?
May 02, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
469 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
