Question about Mitsubishi VS-60803 60" Rear Projection Television
Is there a reset? VS-60803
Is there a reset code or button to reset the menu+2357 settings to factory defaults? if not, does anyone have a list of the default settings for the VS-60803?
    Novelist:
    Champion:
  • 203 Answers
Menu -1-3-7-0
then inital
then enter
DO NOT DO THE E2 RESET!!!!
Let me know if you need more help
Tim nolan
Posted on Sep 17, 2008
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
How to reset Samsung SGH A177 Cellular phone
Hi
Try these codes:
1.)*2767*3855#
2.)*7465625*638*00000000*00000000#
3.)#7465625*638*00000000#
Basically this code work for all SGH Samsung phones.
Regards
Jul 07, 2011 | Samsung Cell Phones
I need to reset a nokia 2126 tracphone to factory settings someone had locked it and dont know the code
To restore factory settings
This option resets some of the menu settings to their original values. It does not
delete data that you have entered or downloaded, or affect entries in your
contacts list.
In the standby mode, select Menu > Settings > Restore factory settings. Enter the
security code, and select OK. See "Change lock code," The default code is 12345.
Mar 05, 2011 | Lands Phones
Mitsubishi vs-60803 turns relay on board then goes
replace the power relay the contacts are burned and, will not latch.
Jul 22, 2010 | Mitsubishi VS-60803 60" Rear Projection...
Convergence settings
With the remote control,hit the menu key and bring up the menu on screen. Then enter 2358 on the remote for the option menu,enter 2357 for the adjustment menu or 2359 for the convergence adjust menu.
Dec 03, 2008 | Televison & Video
HOW TO RESET MY TV LOCK CODE
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357" CONVERGENCE MENU "MENU 2359"
Sep 20, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi vs-60803
greetings from belize take your set to a tech and have him look at it.good luck.
Mar 23, 2007 | Mitsubishi VS-60803 60" Rear Projection...
Mitsubishi vs-60803
You have the typical convergence IC falure that every projection TV encounters at least once in its lifespan. The convergence ICs will both need to be repalce as it will only get worse. if you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Contact list
you go menu,settings,security type in the four digit security code which is normally 0000,1234 or the last four digits of your number go to reset phone ,if it asks to reset phone go yes and it will come up with another message will reset to factory default go yess it will restart your phone to accept changes,another way you can do it is going to menu,contacts and going to your contacts list and just going edit but erase
Aug 29, 2006 | Samsung SCH-a670
Televison & Video Logo
173 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
