Question about Kodak EASYSHARE 5100 All-In-One Printer
Print cartridge reset
I have refilled many ink cartridges in the past and was wondering if anyone knew an easy way to reset the ink level in a cartridge for a Kodak 5300 printer? Thank in advance for your help.
Bob
  • jm05 Sep 17, 2008
    I have the 5100. It is going through ink like crazy. I tried to refill the black but I still get the same "replace black". I need to reset the chip or something. Thanks for any help.
  • Anonymous Mar 25, 2014
    override ink levels, brand new cartridge, but still getting low ink levels
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Update your printer's firmware. Use www.kodak.com/go/downloads make sure your printer is idle before flashing
Posted on Nov 15, 2008
I refill my cartridge hp d1660,how to reset cartridge ink level?
Hum.... D1660 is not easy to reset the ink level.
Whenever you print.... Press cancel buttom first and Press Power button(with holding cancel button) and let go at the same time... should hold about 3 sec.
At least you can get the print out... Little pain in the ****....
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 04, 2011 | HP D1660 InkJet Printer
Canon ip2700 after refill of Black cartridge ink status still shows 'low' and print is very poor - breaks, incomplete - as ink running out. How to reset ink level, or to disable warning, and to get print...
For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
Apr 20, 2011 | Canon iP2700 Inkjet Photo Printer
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
My refilled canon ip1600 ink jets are reading as empty
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Jun 09, 2009 | Canon PIXMA iP1600 Printer
Reset the ink memory level after replacing cartridge
-Mustafa
Apr 30, 2009 | Dell 962 Photo All-In-One InkJet Printer
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Dec 15, 2008 | Canon PIXMA MP470 All-in-One Printer
Printer refills
Some refills won't work on some printers, because the printer actually reads a chip on the print cartridge, a good refil will have been reset, if you did it yourself, or if the company you bought it from did apply the chip reset device on it, the printer will never allow you to use it, thanks HP for the wonderful idea grrr. Be careful with refills anyhow, because some printers use easy clogging ink and refills can be dangerous.
Mar 01, 2008 | Computers & Internet
Refilled black ink before it ran out-now can use at all
After hours of reading about this I finally found the solution. This will NOT reset your levels but you will be able to print without being told you have empty levels.
Start, Control Panel, then Printers and Faxes.
On the next screen, Right click on your printer then on Printing Preferences. Now select the Advanced tab.
Near the bottom left, you will see more options. Click that and then Appearance. Check NEVER display printing status and make sure under Complete-A-Print, all is unchecked. Click OK at the bottom.
You can print without the stupid messages coming up. Dells printer ink cartridges have a computer chip in them and the refurbished ink does not which causes these error messages telling you your ink cartridges are empty.
Jan 14, 2007 | Dell 924 All-in-One InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
834 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
