Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker keeps making ice
I have a whirlpool conquest that keeps making ice, overfilling the bin and falling inside the freezer. I have even turned the switch off, but it continues to make ice. What can I do? I have had problems with it not making ice in the past, but never this one.
  • Anonymous Mar 17, 2014
    i can't get bin back on
  • 943 Answers
Hi thanks for the question it looks like the water valve is not shutting the water valve completely i would replace the water valve thanks the appliance doc
Posted on Sep 22, 2008
I have a Whirlpool White Conquest Side-By-Side Refrigerator GS6SHAXLQ03, manufactured March 2003. The ice maker creates ice and fills the "holding bin" on the interior of the door. However,...
The ice will melt during the defrost cycle. Make sure your freezer is cold enough, at least -5, preferably -10. also, if your freezer is not full of food, put some milk jugs full of water in there to take up space. This will keep the temp colder when the compressor shuts off for the defrost cycle. if there is too much empty space, there is not enough mass to stabilize the temperature and keep it cold.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 4317943 Ice Maker Kit The ice tray overfills with water. Excess water drips into the ice bin & freezes
Probably the dual valve (solenoid) the one that opens when the ice maker calls for water is leaking.It's located in the back of the refrigerator at the bottom behind the cover.To be sure this is the problem turn off the ice maker and after a while if is water the valve is leaking ,if not the problem is with the ice maker.
Aug 23, 2009 | Freezers
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker makes ice but doesnt kick it out
seem likes the heater on the ice maker mold is not working , you'll need to replace ice maker
Dec 15, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side by Side Ice Maker Not Making Ice
sometimes if you use the water filer too long and don't change, can cause this problem.
Jul 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Stop making ice
check if there is ice in the ice maker, see if there is water coming in to the ice maker. maybe a water problem or a solenoid problem...if there is no ice in the ice maker...try to pour manually a cup of water on the ice maker and empty the ice bin so that you can observe if the ice maker is working if there would be ice in the bin after an hour. if there is ice, then a water problem is most likely to look at. i hope the freezer is working perfectly..
Feb 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
146 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
