Question about Pioneer PL-990 Turntable
Pioneer PL-570 turntable (c.1973)
Getting a steady buzzing when playing records and can't determine cause. Any ideas?
Thanks! JWCouillard@sbcglobal.net
  • mrtimsells
    mrtimsells Mar 19, 2013
    What do i connect my pioneer PL-570 to exactly? it only has a red & white cord, but idk what to plug that into..? any help?ut wh
Pioneer PL 570  tone arm drops and turntable shuts off,  what gives?
Posted on Jan 16, 2009
    Problem Solver:
  • 13 Answers
Yes first check is that the Gnd wire from your turntable is connected to the Gnd (ground) post at the back of your amplifier with a good clean tight connection.
If the problem persists, check ALL your hi-fi components mains plugs for earth connections including your turntable, then remove the earth connections on all but one component so that you are left with only item earthed.
What does sometimes cause problems is if 2 or more hi-fi separates are earthed and connected to each other the earth cables along with the hi-fi interconnects form an inductive loop that picks up interferance such as mains hum etc.
Regards John
Posted on Nov 24, 2008
Pioneer Pl990 turntable sounds awful.... I have a pioneer pl 990 record player connected to a pioneer amplifier and a sony CD player. when I play an LP, the sound is bass heavy and I can hardly hear t
When the turntable plays, do you get a howling bass heavy sound? Have you tried turning down the volume and bass? If that corrects the problem, you have what's known as Acoustic Feedback. Check to make sure the tonearm is properly set up first. If it is, please visit my website at Audioserviceclinic.com. You may contact me there. Thank you.
Dec 13, 2014 | Pioneer PL-990 Turntable
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
I just bought a pioneer pl-420 direct drive record player and when i hooked it up to my samsung home theater system via the aux ports in front but when i play records the sound is too low im have to turn...
If the player has a MD/MC pickup head, you need to use an input suitable for MD/MC
(Magneto Dynamic/Moving Coil). If that is not available, you need to buy a standalone
phono pre-amp (pre-amplifier with RIAA-correction curve). Like the TCC TC-400G/L.
Example: See HERE and some info HERE.
Oct 07, 2011 | Pioneer PL-990 Turntable
Re. pioneer pl 990 turntable can the lid be closed
No you cannot play while lid is closed and YES you need an amp/receiver amp
Feb 28, 2011 | Pioneer PL-990 Turntable
Converting a turntable from automatic to manual
I suppose the only way to do it would be to stop it functioning completely. The only way would be to dissasemble the auto function. What you would need to do is work out which parts are essential for the turntable operation and which only activate the return. So you need to whatch the mechanism working. You will need to remove the base and look at from underneath, just like going underneath a car!
I can't say for certain if you can do it, only you will be able to determine it can be removed without affecting the operation of the entire turntable.
May 21, 2010 | Pioneer PL-990 Turntable
My Pioneer PL-570 tone arm returns but will not shut off. It keeps playing like the repeat button is on. I asked this question before and you replyed that on page 8 of the service manuel it shows the...
I have a possible solution to your problem, but will need to talk you thru it. You can register at AudioKarma.com and send a private message to Ghazzer.
Jun 25, 2009 | Pioneer PL-990 Turntable
Turntable tonearm returns but starts playing record over again.
http://www.vinylengine.com/library/pioneer/pl-570.shtml
on page 8 of the above service manual for your model it shows 4 electrical switches that tell the computer what 'state' the mechanism is in at any given time. Either one or more of the switches are intermittant or the mechanism has dried up grease that is slowing down the operation and basically gumming up the works. the old grease would have to be removed and replaced when it is causing binding. The switch just to the right of where is says "microswitch ksf-023" is an 'open air' type and so would be the most likely suspect. it simply needs to be cleaned with a super fine file designed only for cleaning switch contacts. THIS SERVICE SHOULD ONLY BE PERFORMED BY QUALIFIED PERSONNEL ONLY!!!!!
Jan 21, 2009 | Audio Players & Recorders
Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Jan 04, 2009 | Audio Players & Recorders
Pioneer PL-990 Turntable Logo
1,393 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
