Question about Maytag Performa PAV2200
Maytag Performa washer
When my wqsher drains the water before spin or rinse, it leaks out from underneath the washer. It does not drain out properly. Solution?
  • 39 Answers
Hi jamac74
The leak could be comming from one of 2 places, either the pump or the main seal. the best way to find wherer the leak is comming from is to take the front panel off. you can do this by poping the top up there is 2 clips that hold the top down. use a putty knife to pop the top up then there is 2 screws holding the front on.
Posted on Sep 21, 2008
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
My maytag performa washer continues to drain while filling, therefore never starting the rinse cycle. The drain pipe is in a loop position so I know it is not siphoning the water out and the washer seems...
how far does the drain pipe go into exit drain because this shoulh not pushed into pipe more than 6" and should have a air break and also the drain pipe should be above top of bowl line
Nov 19, 2009 | Maytag Performa PAV2200
Washing machine leaks from underneath after rinse cycle...wash cycle runs fine, but when it drains out after rinse cycle, it leaks from underneath
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Maytag performa washing machine
yes im a expert (laugh)...your drain hose is to low..the drain hose must go up the height of the unit abut 3 feet before it can go down...now if you have your drain hose connect directly to your drain pipe ,,the waste pipe will **** the in coming water right out of unit,,we call this a sphion effect...booth easy fixs,,,onthejob
Jan 22, 2009 | Maytag Performa PAV2200
My matag performa makes isn't spinning or draining the water
im sorry to say the problem you have is in the transmition a new transmition thrust bearing and seal kit would be needed to repair this properly parts alone you are looking at 250 - 300 dollars
Jan 19, 2009 | Maytag Performa PAV2200
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
Maytag Performa...It fills up and will not spin.
There are to devices that can cause this. The lid switch and the water level control valve.
Jan 09, 2008 | Maytag Performa PAV3200
when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
Jul 03, 2007 | Maytag Performa PAV2200
Washing Machines Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
