Question about U-Line 15R Compact Refrigerator
Cold Control I was told that the cold control replacement part for the Model 15R was discontinued. I ordered the new one and it has the electrical terminals on the side and not on the back. Problem is that it won't fit against metal guard. Solution?
  • 8,205 Answers
Find another spot to mount it or turn it wide open and tape it off.
Posted on Jan 31, 2009
WHERE IS DEFROST TIMER ON MAYTAG 20.6 CU FT FREEZER ON TOP MODEL M1TXEGMYW
Your model does not have a defrost timer, it has something called an Adaptive Defrost Control Board. Your model uses this board=> HERE The ADC can be found behind the control panel inside the fresh food compartment above the top shelf item location 4 in this photo=> HERE
APPLIANCE911
Aug 27, 2016 | Maytag Refrigerators
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
Where is Mercedes SL500 03 Driver side fuse box number written?.
Fuse Terminal Cable ID (fused) Fused function Rating in amperes (A) F1 30 - Wiper park position heater relay (K40/2kA) F2 30 - High pressure and return flow pump relay (K40/2kF) F3 30 - Steering column forward/back adjustment relay 1 (K40/2kD)
Steering column forward/back adjustment relay 2 (K40/2kE) F4 30 - Steering column height adjustment relay 1 (K40/2kI)
Steering column height adjustment relay 2 (K40/2kJ) F5 15R - Wiper On and Off relay (K40/2kH) F8 30 RD 0.75 Central gateway control unit (N93) F9 30 PKWH 2.5 Left door control unit (N69/1) F10 15 BKVT 0.75
BKVT 0.75
BKVT 0.75 Left front headlamp unit (E1)
Right front headlamp unit (E2)
Xenon headlamp control unit (E1n1, E2n2) 15 RDGN 0.75 Restraint systems control unit (N2/7) F11 15R BKYE 1.0 Circuit 15R/30 cutoff relay (K75) F12 15R - Spare F13 30 RDGN 1.5 ABC control unit (N51/2) F14 15R BKGN 0.75 Windshield washer fluid pump (M5/1) F15 30 RDGN 1.0 Data link connector (X11/4) F16 15R PKYE 1.0 Valid for code (855) TELE AID:
D2B telephone and TELE AID transmitter/receiver (A35/17) 15R PKYE 1.0 Valid for code (853) MB standard telephone:
D2B telephone transmitter/receiver (A35/13) F17 15R RDYE 0.5 Vehicle-sensitive seat belt lock sensor (A60) F18 15R - Spare F19 15 BKYE 1.00 Valid for engines 112.973, 113.963/992:
Fused via circuit 15 connector sleeve (Z3/29):
Cylinder 1 ignition coil (T1/1)
Cylinder 2 ignition coil (T1/2)
Cylinder 3 ignition coil (T1/3)
Cylinder 4 ignition coil (T1/4)
Cylinder 5 ignition coil (T1/5)
Cylinder 6 ignition coil (T1/6)
Cylinder 7 ignition coil (T1/7)
Cylinder 8 ignition coil (T1/8) F20 15 BKGN 0.75 Data link connector (X11/4) F21 15R BKYE 0.5 Instrument cluster (A1) F22 30 RDYE 0.5 Instrument cluster (A1) F23 30 RDWH 1.0
RDWH 1.0 AAC [KLA] control and operating unit (N22)
Coolant circulation pump (M13) F24 30 RDWH 0.5 Stop lamp switch (S9/1) F25 30 RDYE 0.75 Alarm signal horn (H3) F26 30 RDBU 0.5 Lower control panel control unit (N72) F27 30 RDVT 2.5 Left front seat adjustment control unit with memory (N32/1)
Apr 22, 2015 | 2003 Mercedes-Benz SL-Class
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 | Ovens
The light is on, but the compressor is not operating.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | U-Line 15R Compact Refrigerator
Can I use a refrigerator on electric only if it developed a leak on the boiler tube
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Leo Ponder
Aug 16, 2011 | Dometic Refrigerators
Pluged in not running
most of the time these are either stuck in defrost or cold control is bad and sometimes the overload on compressor is bad...the relay can be bad or even the compressor.....BUT, check cold control and see if its stuck in defrost..no model given , but locate defrost timer...if a manual type..you can advance it out of defrost. if it comes back on..order new timer...if not it..remove cold control and make bypass on terminals to see if it comes on.., is , order new cold control,,...UNPLUG before doing anything
Jan 28, 2011 | Kenmore Refrigerators
F-2 and F-3 codes keep blinking and ther is a loud beeping sound ,usually when oven is heating up and after oven is heated up and when oven is cooling. occasionaly it happens on a cold oven thanks
Hi, F2 and F3 means Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Jan 04, 2011 | Fisher and Paykel AeroTech Double OD302...
How to troubleshoot the electrical air conditioning system 2000 GMC Yukon Denali. I put in new resistor, relay and dealer blower motor and it still doesn't do anything. Air conditioning control switch...
The compressor on the air conditioner in my 2000 GMC Yukon XL went out last summer. Had it and the whole line replaced at a local air conditioning shop last fall. Used it little before cold weather. Warm weather this spring and no cold air. We could hear the compressor trying to kick in. The shop told us that the control console was bad and had to be replaced. They told us the part was on back order and did not know if they would be abel to get one any time soon. We took the Yukon into the local GM dealership. They told us that the high side fitting was bad and that the freon was very low and that they would have to deal with that first to check the system. Called back to the air conditioning shop and they said they had a console come in and they would put it in and check the high side fitting. I now have cold air and questions. Bought Yukon in 2005 used, had always had problem of not switching to cold air once the heater has been used. We were told changing the console should fix that. It has not changed. I feel like the console angle was a scam, that the system was just low on freon. Each shop was blaming the other for trying to scam me. And what can fix the heat to cold issue? If anyone has answers I would sure appreciate the knowledge.
Jul 02, 2010 | 2000 GMC Yukon Denali
U-Line 15R Compact Refrigerator Logo
154 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
