Question about HP Deskjet F335 All-In-One InkJet Printer
Plug prblems Where do I plug the printer into the computer??
  • 305 Answers
Into any USB socket. you put the square end into printer, the other, flatter end into a USB socket at back of pc
Posted on Sep 17, 2008
When i power on my d860 camera then display connect the computer , printer so plz solve the prblem
It seems your camera is not installed, or the installation is corrupted.
Please, try reinstalling your camera:
1.Start>Control Panel>Uninstall a program>find your camera, click on it and hit Uninstall, confirm if prompted.
2. Restart your computer.
3. Insert your installation disc-the one you got with the camera, plug in the camera (connect with the computer, and start installation.
4. When installation finished, unplug the camera (disconnect from the computer) and restart your computer.
Should work now.
Jun 20, 2011 | Computers & Internet
The trac light is on and i want to know if i have a prblem
the traction contol is mafunctioning bring it to auto zone and have them plug the computer into it and check the coads that come up and then erase the code and if its not broken witch it probibally isnt then the light will go out if u get the code erased
Mar 05, 2011 | 1999 Oldsmobile Alero
My laptop is not starting when I plug in adopter the charging light shows but when I press start button light goes off and it does not start. Is this a battery problem. I always use the charger/adopter to...
Try removing the battery and then starting the computer with the power cord. Sometimes the battery is bad and prevents the computer from working properly.
Aug 02, 2017 | Acer Ferrari 3200 Notebook
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
Headset symbol displayed with no headset plugged in
i'm getting so so tired of these ridiculous problems. you shouldn't own a phone if you can't solve these sorts of prblems yourself. pathetic!
Feb 12, 2009 | Nokia N73 Cellular Phone
try disconnecting blue plug at the trans on the left side......
You may a prblem with the over drive..
See torq convertors will lock up and couse engine to stop..
Feb 09, 2009 | 1990 Oldsmobile Cutlass Ciera
Where does plug go ?
Need to known what plug it is to answer that if its a usb plug it goes to the usb port but if its the big printer plug you would have a slot on the back of you computer box that would take that either a printer port or com port
Sep 16, 2008 | HP Deskjet F335 All-In-One InkJet Printer
7110 supply expired
According to posts on a another forum, you can fix this problem by unplugging the printer, removing the battery or sticking a business card between the battery and its contact point. It should work when you plug it back in.
Jun 15, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Printer install
Hi this should be easy to do get the printer and plug the lead into the slot on back of printer then plug the other end into your computer their should only be one place it will fit in back of computer plug the lead in their might be picture of printer on back of computer it will be small and near a printer port.
The port in back of your computer is about 2 inches long or about 5 or 6 cm then plug the lead coming from printer into the port.
Now plug printer in and swtch on then switch computer on.
Now once your computer has started up you might get message new hardware found or start hardware wizard if you have disk that came with printer put this in your comp and follow instructions if you dont have disk let me know then i will talk you through the process let me know if your having problems ill be glad to help ok speak soon good luck but you should have no problems as its all plug and play and should set itself up.
If your printer is using usb port and not printer port then it will need plugging into any usb port on either the front of computer or back if you are unsure then let me know ok ill gladly help you ok
Feb 20, 2008 | Office Equipment & Supplies
HP Deskjet F335 All-In-One InkJet Printer Logo
19 people viewed this question
Ben Johnson
