Question about RCA P60828 TV
RCA p60752eb no picture porblem
Hey I've seen a couple of your replies to other people's problems and you seem pretty knowledgeable about t.v's. I have a RCA p60752eb t.v and when i turn it on I get sound, no picture. I can change channels and turn up and down the volume I just don't get any picture. Please help. Let me know asap. Thanks
  • RCA Master
  • 8,617 Answers
Most likely its a vertical deflection issue, try soldering the vertical otput IC as that may just need to be resolderd, if that doesnt help try replacing the Vertical output.
Posted on Sep 18, 2008
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
Tv picture goes off but still have sound.
Resolder all poor connections on power supply board and this should fix your problem.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Does my RCA 42" LCD TV have a USB Port
hey dont use its for refix the so on the tv is only for service not for use
Dec 28, 2008 | RCA L42WD250 42 in. LCD HDTV
Rca p60752eb
Sounds like the flyback, can you look on the rear tag and let me know which chassis you have and verify your model number and I will post which flyback you need as well as where to get a replacement with free tech support to help you install it.
Jul 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P60752EB Power problem
Apparently, blown fuses indicate problems elsewhere in the circuit. The block is a voltage dropping resistor, has nothing to do with problem. If you think it's worth it, take to pro/tech
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca projection tv has no picture or osd
Check the bulbs. If one is burned out, you will get this problem. The bulb is easy to change but will run you about $300.
Feb 10, 2008 | Televison & Video
Rca projection tv has sound,no picture or OSD
The 169 is an old chasis but a good one. Many chronc problems can cause these symtons. No high voltage because of bad flyback, or HV spitter defec is the most likely, but there are chonic caps that fail in the power supply as well. This problem will most likely need the assistance of a qualified service professional.
RCA rear veiw projection tv
do you see any tiny lites you see on the end of the tubes or crts are the filiments?
Feb 04, 2008 | Televison & Video
RCA P60828 TV Logo
150 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
