Question about Canon PIXMA MP160 All-In-One InkJet Printer
Pizma mp160 The thin plastic strip that runs behind the cartridges has come loose. Can anyone tell me how to reattach it?
  • loissoll Sep 27, 2008
    Thank you for the response, but I guess the difference of brand makes a difference. I couldn't see the kind of connections you're talking about. I couldn't figure out how to get the top of the printer off either.
I just fixed this problem on a Lexmark X3350. All you have to do is feed it behind the cartridges through the grooves and hook it on one end and then on the other with a small spring. The notch with the small print in it also rests on a small metal post to make sure it doesn't go too far in either direction. It makes it a lot easier if you take apart the top to get in there. Of course this was done on a Lexmark X3350, but it should be the same principal.
Posted on Sep 23, 2008
My canon MP258 show error code on screen E03, what should i do. help someone can help me. really appreciate it.
That is due to the clear plastic strips inside the printer, the one that run behind the cartridge holder, being dirty or damaged. This plastic strip with black marking on it, is used to tell the printer where the cartridges actually are. Unfortunately it could also be the sensor that reads this strip being damaged. Inspect the strip with a bright torch to see if any ink or dirt is on this strip, use a bright torch when doing so, it makes it much easier. Also check behind the cartridge holder for any torn bits of paper that could be jammed in it. Make sure the printer is unplugged from the power during this!!
I hope this helps
Regards GM
Apr 08, 2011 | Office Equipment & Supplies
Hi - E5 - Part popped out
Turn off and unplug the printer and slide the cartridge carriage over by hand. You could remove the cartridges. Then after reconnecting the cable, slide carrier back by hand and reconnect the power.
Jul 17, 2010 | Canon PIXMA MP160 All-In-One Printer
I have a 944. This long clear plastic strip marked h-04 became detached. now the ink cartridge flies back and forth and. help please?
You will have to open the machine and reattach that plastic strip because that strip senses which side of the machine the cartridges are
Oct 30, 2009 | Dell 922 All-In-One InkJet Printer
What do I do to resolve Error 5100?
open the printer so you can see the cartridges, if you look what the cartridge is sitting on that is called the cartridge harness, right behind the harness and it runs right through it is a thin code strip, this strip is about a quarter of an inch wide and runs the length of the printer and now you need a small bottle of 99% isopropyl alcohol and a couple of Q tips, now bend the Q tip at the end to 90 degree's and now dip the Q tip into the alcohol, and clean the plastic code strip, be real carefull not to break this or you will be e mailing me like crazy, do the whole strip front and back, move the harness to get it all, when that's done realign the printhead, go to start, to control panel, right click on the printer icon and go to properties, to maintenence to print head alignment and do that, hope this helped and good luck.
Aug 30, 2009 | Canon PIXMA iP1600 Printer
Where is the encoder strip on brother fax machines?
I am familiar wih some inkjet models. The encoder strip would usually be behind the ink cartridge carriage. It is a thin clear plastic strip across the length of the carriage. The ink cartridge housing glides back and forth along the encoder strip.
Aug 25, 2009 | Brother MFC-685cw InkJet Printer
The runner in the printer
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
May 08, 2009 | Lexmark Z845 InkJet Printer
Ink moving very fast
Take a peak inside the printer where the ink Cartridge is and see if you notice anything out of place usually it has thin long plastic strip found behind the ink carriage unit make sure its there if its not there then u need to put it back into position you gonna need to take the printer two side cover off to do this
May 10, 2008 | Canon PIXMA MP160 All-In-One Printer
Child damaged HP6110 - Help
It stretches from left to right behind the cartrige assembly and the assembly slides on it. It's a sensor strip for positioning the cart. asm. I'm not sure how it attaches, but you'd have to take the unit apart to do it.
Good luck...
Mar 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
