I have quickbooks pro 2006 and I purchasaed a new computer with Vista. Where can I get a patch to allow my 2006 XP version to run on vista
    Scholar:
  • 60 Answers
By the looks of it, no patch is necessary. The only thing it requires to run is administrator privileges. To do this you can do it one of two ways.
Rightclick the quickbooks pro icon.
Goto Properties
Select the tab labeled "Compatibility"
On the bottom of that tab put a check in box captioned "Run this program as an administrator"
Then press Apply and OK.
Now every time you startup this program it will be with administrator privileges.
Posted on Sep 17, 2008
Does QuickBooksPro 2005 version run with windows vista
I think Intuit draws the support line at 3 years Even though you have probably registered your product, if there is any trouble with it and the new computer, you will be on your own. I think you would be putting yourself in unnecessary jeopardy to upgrade as you describe at this time. (Your business depends on your computer and software, to operate) You must also be aware of Vista troubles.
If you are in the market for a new computer, you may opt for the new Windows 7 OS and possibly upgrade your Quickbooks at the same time for maximum benefit.
If you have the Vista computer - you already have the Quickbooks, it costs nothing to give it a try. Presumably, you have a XP computer with Quickbooks on it now ... If the Vista - Quickbooks combo doesn't work out you could upgrade the Vista to Windows 7 ... you have nothing to loose in this senerio.
I hope I have provided a little insight for you to consider.
Thanks for using fixya.com
a
Oct 25, 2009 | Intuit QuickBooks: Pro 2005 for PC
How can i make quickbooks 2005 run on a vista laptop?
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
Installed Quickbooks 2009 non profit edition. Finished the interview and created a company. Try to edit/create new from Quickbooks' suggested chart of account but the account list shows "?" mark on each...
Try running all the updates that are availible for Quickbooks 2009, I know there were quite a few bugs with Vista that the patches were supposed to take care of. Let me know if that helps.
Mar 16, 2009 | Intuit QuickBooks Premier Nonprofit...
I've upgraded my QP Pro Contractor 2006 to my new computer Vista 64. I do not seem to be able to upload/restore companies from 06 to 09, it just will not take the data.
2006 was not designed for operating in Vista. If the data files are not upgrading to Version 2009, it usually indicates data damage in the file. It will probably need to be rebuilt in 2006, then updated.
Mar 03, 2009 | Intuit QuickBooks Pro 2007 Full Version...
I cannot install quickbook 2005 with vista , also i install flash player 7 and installtion was stop becouse it can not see it
2005 was not designed to work on Vista. Vista was barely even on the drawing boards in 2005 ( and the 2005 version was programmed in 2003/2004). The file structures for XP and Vista are very different and 2005 is not compatable.
Nov 28, 2008 | Intuit QuickBooks: Pro 2005 for PC
Updating Quickbooks on Vista OS
There are a couple of things going on here.
First, and most important, Qb 2005 was not designed to run on Vista. Vista was barley even in the planning stages when 2005 was programmed. Vista will probably run it, but in a compatability mode ( pretending to be an older version of Windows), but updating the program will be nightmarish at best because the updates are pointing to files that are either 1) no longer used by Windows or 2) the versions and functionality of the files has changed.
My best advice- restore the backup on an XP box, or get a later version of QuickBooks that will run on Vista.
Oct 17, 2008 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks Pro-restoring a back up from a previous version 2005
If is any help - we have just had the same problem.......had version 5 (very old) of QB
changed computer to Vista and would not work so had to buy Pro 208 for Vista . We really had to get in touch with Quickbooks - they send you a free upgrade kit (disc which is Pro 2006 version (not a fuull version but enogh to get the data over) then you load that on your old machine transfer your data to that then copy that again - then load into Pro 2008 - worked fine for us - have come across a hiccup with VAT - but however I guess we are going to have to give in and phone them after the Bank holiday........apart from that everything was fine.
be brave and phone 'em - tech support was helpful.
May 05, 2008 | Intuit QuickBooks Pro 2008: Windows
Is quick books 2003 Vista compatabile?
QuickBooks Pro 2003 can run on Windows Vista. Right-click a shortcut to open Quickbooks (or qbw32.exe directly) and click on Properties. Select the Compatibility tab. Under Compatibility Mode, check the box and select Windows XP (Service Pack 2) from the list. Under privilege level, select "Run this program as an administrator." Select OK and everything will work.
Feb 14, 2008 | Intuit QuickBooks Pro 2003 Single User...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
