Question about Sewing Machines
Timing my sewing machine pfaff 332
Why is the bobbin case not moving right to allow the needle to go in and out freely. It breaks the needle when it tries to come back out.
5 Suggested Answers
  • 323 Answers
SOURCE: Needle hits bobbin outer casing
Your hook/needle timing is off and it needs to be seen by a technician before you damage the hook. Some dealers can do a 24 hour repair for an additional charge.
sewman7
Posted on Jun 09, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
talk2ginny
  • 34 Answers
SOURCE: Anna had this problem with her Pfaff 332 sewing machine, I do too
Hi - it is possible that your needle is bent. Insert a new needle and check again - if you have the same problem, your timing is probably off. You could try buying a new bobbin case to see if that solves the problem. If you have had your machine tuned up within the last year or two, I would recommend a tune-up. If you know of a reputable sewing machine repair shop or dealer, the tune up should include correcting the timing and will extend the life of your machine.
Good luck,
Ginny
Posted on Jan 31, 2009
SOURCE: while sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Posted on Feb 05, 2009
  • 6 Answers
SOURCE: timing my pfaff 332 sewing machine
There are two parts to the sew hook on that machine. The outer part has the hook point that grabs the thread off the needle. Then there is an inner part which has a post in the center of it that the bobbin case fits on to. The inner part should be held in place with an arm that has a bump on it. It keeps the inner part from spinning around. Sometimes this arm slips loose and a notch in the inner part of the hook assembly slips out from under the knob on the arm. If this is what is happening, you need to loosen the screw holding the arm in place and reposition the notch of the inner part of the hook back under the bump on the arm. There needs to be clearance between the notch and the bump for the thread to pass between the two. And the bump should be in line with the needle when it is in its lowest position.
If this doesn't solve the problem you need to take the machine in for repair.
Wayne
Posted on Mar 12, 2009
Needle Jams In Bobbin Case Area pfaff 1540
First, make sure there is no debris and scraps of thread in the bobbin area. I'm sure you did that already. I assume you also tried it with another thread just to be sure. I would suspect that the timing went out of whack. The machines depend on a synchronization between the needle motion and the bobbin action underneath. I once had a Singer that slipped and I had to reset the timing. If it is the timing synch problem then it would happen consistently and not work sometimes and then not work other times. G
Jan 27, 2014 | PfaFF Sewing Machines
Thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
Pfaff Varimatic 6085 purchased June 2001. Second time this has happened and it cost $60 to repair. When the needle is centered it hits the case holding the bobbin. If I move the needle to the right it...
Many users also had the similar bobbin locking problems. I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Aug 17, 2010 | PfaFF Creative 7570
I have a Pfaff Expression 2038 that has been fixed three times for the same problem. Needles keep breaking off and the bobbin mechanism is revolving freely. I just had it repaired a week ago and the...
I have a Pfaff Expression and the bobbin casing does not come out so I can clean out behind there. Usually in my other machines there are 2 little levers that turn and then you can pull the whole bobbin shuttle out
Jul 04, 2009 | PfaFF Sewing Machines
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Jan 30, 2009 | Sewing Machines
Timing my pfaff 332 sewing machine
Wayne
Sep 16, 2008 | Sewing Machines
Sewing Machines Logo
272 people viewed this question
Top Sewing Machines Experts
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
