Question about Samsung SPH-a660/VI660
Sansung SPH A660 cell phone time clock frozen and will not advance until you touch some buttons to wake up the software for the time to update, therefore the alarms are useless because they are tied to the clcok which does not update.
    Top Expert:
  • Samsung Master
  • 9,472 Answers
You may need a software update to your phone. You will need to call your cell provider and inform them of the problem. A software update will usually clear this up.
Posted on Sep 20, 2011
SOURCE:
How do I change the time back an hour on the Samsung SPH-A660...its driving me nuts!!!! There is nothing in the manual for this either.
The Time on most Cellular Phones is controlled from the Network, so there is no way for the user to manually adjust it. Try turning the phone off for a few seconds, and when it boots back up, the time should be updated. If not, it might take another hour or two, but it will eventually be correct.
hope this helps
R
Nov 07, 2010 | Samsung SPH-A660 Cellular Phone
After i leave the main screen and go to lets just say text msgs....when i want to go back to main screen it will not allow me to go...seems like it freezes on current screen...
First you have to restart the phone and the reset it.Beacause the apple ios is corrupted you have reset the ios to work properly.When you reset the apple i phone new Ios will be re-installed it will not update it will only reinstall so the firmware will work properly.
To restart iPhone running iOS 3.0 or later
1. Press and hold the Sleep/Wake button until the red slider appears. When the red slider appears, release the Sleep/Wake button.
2. Instead of dragging the red slider, press and hold the Home button for six seconds.
3. If the device does not return to the Home screen, see the steps below to restart.
To restart iPhone iOS 2.2.1 or earlier
1. Press and hold the Home button for six seconds.
2. If the device does not return to the Home screen, see the steps below to restart.
If the iPhone touch remains unresponsive, try restarting the device:
Restarting iPhone :
1. To turn it off, press and hold the Sleep/Wake button until the red slider appears.
2. Slide your finger across the slider to turn off iPhone.
3. To turn iPhone touch on, press and hold the Sleep/Wake button until the Apple logo appears.
Resetting the iPhone:
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
If still the problem persist you have to update the firmware:
Updating and Restoring iPhone Software
You can use iTunes to update or restore iPhone software. You should always update iPhone to use the latest software. You can also restore the software, which returns iPhone to its original state.
If you restore, all data is erased from iPhone, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone settings are restored to their original state.
1. Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2. Connect iPhone to your computer.
3. In iTunes, select iPhone in the Source pane and click the Summary tab.
4. Click “Check for Update.” iTunes tells you if there’s a newer version of the iPhone software available.
5. Click Update to install the latest version of the software. Or click Restore to restore iPhone to its original settings and erase all data on iPhone. Follow the onscreen instructions to complete the restore process.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 04, 2010 | Apple iPhone Smartphone
Iphone 3gs wont work. white flashlight screen?? please help
If iPhone doesn't appear in iTunes or you can't sync iPhone
  1. The iPhone battery might need to be recharged. For information about charging iPhone, see "Charging the Battery" in the iPhone User's Guide.
  2. If that doesn't work, disconnect other USB devices from your computer and connect iPhone to a different USB 2.0 port on your computer (not on your keyboard).
  3. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    Note: If you enter the SIM PIN incorrectly three times, you may need to contact your carrier for a Personal Unlocking Key (PUK) to enable your SIM card again.
  4. If that doesn't work, restart your computer and reconnect iPhone to your computer.
  5. If that doesn't work, download and install (or reinstall) the latest version of iTunes.
If you can't make or receive calls, send or receive text messages, or access email or the web
  1. Check the cell signal indicator in the status bar at the top of the screen. If there are no bars, or if it says "No service," try moving to a different location. If you're indoors, try going outdoors or moving closer to a window.
  2. Check to make sure you’re in an area with network coverage. Go to your carrier's website to see network coverage areas.
  3. Make sure airplane mode isn't on. From the Home screen choose Settings, then turn Airplane Mode off.
  4. If that doesn't work, turn airplane mode on, wait 15 seconds, then turn airplane mode off again.
  5. Make sure to include an area code for every phone number in your contacts list that you use to send or receive text messages.
  6. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  7. If that doesn't work, there may be an issue with your wireless service. Call your carrier or go to your carrier's website.
  8. If that doesn't work, restore the iPhone software. See Backing up, updating, and restoring your iPhone and iPod touch software or see "Updating and Restoring iPhone Software" in the iPhone User's Guide.
MMS: Original iPhone does not support MMS. MMS is available on iPhone 3G and iPhone 3GS if it is supported by the wireless carrier. For more information, please see iPhone: System requirements for MMS.
If iPhone won't turn on, or the display freezes or doesn't respond See iPhone and iPod touch: Frozen and unresponsive for information on addressing these symptoms.
  1. iPhone OS 2.x and earlier: Press and hold the Home button until the application quits.
    iPhone OS 3.x and later: Press and hold the Sleep/Wake button until the red slider appears, then press and hold the Home button until the application quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
If iPhone continues to freeze or not respond after you reset it
  1. Reset iPhone settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but no data or media is deleted.
  2. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears restore the iPhone software. See Backing up, updating and restoring your iPhone and iPod touch software.
Jun 28, 2010 | Apple iPhone Smartphone
Its frozen and it won't unlock
Try one of these steps:
- Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
-press in the sleep/wake button on the top left of the device, and the big circular home button on the front face on the bottom. Do this for roughly 10 or more seconds and the device should shut down/off. Give if a moment and then restart the device.
-*WARNING* This method can erase all of your personal content on iPod...
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all yourdata and media are removed from iPod touch.
  • If that doesn't work, restore the iPod touch software. See "Updating and Restoring iPhone or iPod touch Software."
Feb 16, 2010 | Apple iPod touch
How can reset iphone 3G?
Hold down the "Sleep/Wake button and the "Home" button for about 10 seconds, or until it says "Slide to power off."
Hope this helps!
Sep 28, 2009 | Nokia N73 Cellular Phone
When i press the ringer button on the side, or the # buttons 2 5 8 or 0 on my sph-a660 phone, the phone starts ringing or vibrating or just repeating any combination of those numbers and changing the...
Buy a different phone and read reviews on CNET where you would've seen this http://reviews.cnet.com/cell-phones/samsung-sph-a660-sprint/4505-6454_7-30732916.html?tag=mncol;lst
This was a base model when it was put into production and so Sprint never had any intent of investing in things like quality control as some of these phones work perfectly fine and other have tons of problem
Dec 02, 2008 | Samsung Lands Phones
Samsung cell phone manual/sph-a660
i willl give you the website link just go to the link you will get the samsung a660 s user manual download it ...
www.samsungtelecom.com/pdf/A660.pdf
www.cellphones.ca/cell-phones/samsung-a660/
go to any of this sites it s available for free ....
Feb 07, 2008 | Cell Phones
Powered off
Plug it in and charge the battery. You should be able to turn it on while it is charging by pressing the power button. If it doesn't respond right away try holding down the power button until it turns on (well, at least 10 seconds or so). It is possible that the battery lost it's charge completely, but that's unlikely unless you have run it dry multiple times.
Jun 19, 2007 | Samsung SPH-a660/VI660
Samsung SPH-a660/VI660 Logo
67 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
