Question about Maytag MER5755QAS CleanDesign Electric Kitchen Range
Maytag Stainless Steel & Black Electric Oven won't heat over 140 degrees
My oven won't heat over 140 degrees. The oven was operating fine and then on the last batch of cookies set at 375, the oven immediately began to decrease in temperature. It will not heat to over 140 degrees. Model #MER5755QAS.
The oven is only 3 years old and came new with our newly built home (DR Horton home)
If it is the thermostat or sensor, where is it located? The manual does not tell how to replace it.
  • latoyalawson Dec 04, 2008
    I have the exact same problem in a DR Horton home!! Oven and House 3 years old. Help
    Habit-Forming:
  • 171 Answers
On a 220 volts stoves when the electrissity drops to 120 volts thats what it does.so oven element wires most be check for power, if it's getting 220 replace the element.
Posted on Dec 07, 2008
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
Jan 03, 2015 | Maytag Gemini 30" Self-Cleaning...
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
The oven will not heat up over 170 degrees (after a half hour) and I hear a lot of clicking in the control panel
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jun 17, 2011 | Maytag 30" Self-Cleaning Freestanding...
My Maytag Gemini double oven gas...........the bottom oven won't heat up past 100 degrees. What can I do to troubleshoot?
Hi
This issue seems to be with the gas inlet valve or the igniter itself that is bad. Gas Valve has a bi-metal that open when a certain amount of current flows through it to heat it up. Make sure that the glow bar is not cracked. Faulty igniters can allow correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. Hope this helps... Please post back if you need more information.
Daniel
Jan 18, 2011 | Maytag Gemini 30" Self-Cleaning...
Bottom oven will not heat up past 230 degrees
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 15, 2011 | Maytag Gemini 30" Self-Cleaning...
The oven wont heat over 105 degrees
heatman101
Nov 23, 2010 | Maytag MEW6530DDS Stainless Steel Electric...
Oven temperature in main oven does not reach above 200 degrees. Is this a coil problem or a themostat problem?
heatman101
Sep 05, 2010 | Kenmore 75503 Stainless Steel Dual Fuel...
Maytag 30" PGR571DBDQ stove. Oventook over 30 minutes to reach 350 degrees
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 13, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Lost manual for self cleaninf Maytag oven. It's about 8-10 years old.
My answer is to NOT use that feature, as generally after most people use that :Feature" straight after the oven faults, you see that "Cleaning" mode simply heats the oven up wayyy up to like 900 degrees up, and after this the temperature sensors generally "Go" so my advice is ... use elbow grease and save a lot of possible problems, especially with a 8 - 10 yo unit.
Mar 16, 2010 | Maytag Gemini 30" Self-Cleaning...
Why won't my Maytag electric oven heat past 210 degrees?
Hello could be oven thermostat,when you are sure of the part you need check out www.appliancepartssolutions.com cheep parts!
good luck
Apr 08, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Maytag MER5755QAS CleanDesign Electric Kitchen Range Logo
325 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
