Question about Sewing Machines
Timing my pfaff 332 sewing machine
When bobbin case is out, I see that the inner part of where it normally snaps in, spins around, and blocks the spot where the needle is to come
cleanly down and back up with the thread from the bobbin. Is this a timing problem? Can I fix this myself? I have a Pfaff 332 sewing machine.
Thank you for any help you can give me. Anna
  • Anonymous Jan 30, 2009
    Anna had described my problem exactly.
    Problem Solver:
  • 6 Answers
There are two parts to the sew hook on that machine. The outer part has the hook point that grabs the thread off the needle. Then there is an inner part which has a post in the center of it that the bobbin case fits on to. The inner part should be held in place with an arm that has a bump on it. It keeps the inner part from spinning around. Sometimes this arm slips loose and a notch in the inner part of the hook assembly slips out from under the knob on the arm. If this is what is happening, you need to loosen the screw holding the arm in place and reposition the notch of the inner part of the hook back under the bump on the arm. There needs to be clearance between the notch and the bump for the thread to pass between the two. And the bump should be in line with the needle when it is in its lowest position.
If this doesn't solve the problem you need to take the machine in for repair.
Wayne
Posted on Mar 12, 2009
The top thread will not pickup bobbin therad it is a pfaff 5.0 machine
The bobin may not be in correctly. When looking at the bobin, with the thread threaded through the bobbin case, make sure that it spins counter clockwise. Also the problem could be caused by the machine not threaded correctly. But it is more likely the bobbin case and bobbin
May 04, 2017 | PfaFF Sewing Machines
5.0 pfaff will not pickup bobbin thread when getting ready to sew
Make sure your bobbin is spinning in the correct direction when installed, and that it is the correct bobbin case as well.
Cheers,
Chance
Embroidery Services
San Diego, CA
What size bobbin for a pfaff creative sensation
Bobbins (10pk), Pfaff #820921096: Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts > Creative 2.0
  1. Cached
  2. Similar
Product Details. Guaranteed to fit Pfaff Sewing Machine Models: Group J: creative sensation, creative sensation pro, creative performance, creative vision, ...
Pfaff - creative sensation™ pro
www.pfaff.com/en-US/Machines/creative-sensation-pro
  1. Cached
Now your PFAFF® creative sensation™ pro can embroider faster than ever ... needed to achieve perfect balance between the needle and bobbin threads.
Pfaff - Accessories
www.pfaff.com/en-US/Accessories?page=5
  1. Cached
Results 161 - 200 - Revel in a wide range of PFAFF® accessories .... blue bobbins for sewing, embroidering or experimenting with the creativeBobbin Case. bobbin for pfaff creative sensation Google Search
Dec 31, 2016 | PfaFF Sewing Machines
My bobbin winds unevenly, there is always more thread at the bottom of it than there is at the top. Neither switching to the original pfaff bobbin nor either spool position works.
I always use my finger to guide the thread as the bobbin is winding,the bobbin shouldn't be moving around in the metalcase probably needs tightened.
Aug 29, 2015 | PfaFF Sewing Machines
Pfaff 1221: was sewing fine; now top thread doesn't catch bobbin thread
try rethreading the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and if that doesn't help, the problem could be a timing issue and would require a sewing machine shop
Apr 15, 2015 | PfaFF Sewing Machines
I have a Pfaff 418 and suddenly the bottom thread keeps snapping after about 5cm. I've altered the tesion & the timing and it's still happening. Any ideas??
try changing the needle
clean under the needle plate & in the bobbin area for lint or threads
if these suggestions don't help, then the machine needs to be checked
to see what wrong with it
May 29, 2012 | PfaFF Sewing Machines
Hi, I've recently acquired a Pfaff 230 s#5 150 268, need parts
HI. Sew4Less.com (http://www.sew4less.com/index.php) has parts for your Phaff 230, including belts, a bobbin case, and both service and repair manuals.
SewingManuals.com (http://www.sewingmanuals.com/index.htm) has both the user and service manuals.
Hope this helps!
Happy Sewing!
Robbie
Mar 21, 2010 | PfaFF Sewing Machines
Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Jan 30, 2009 | Sewing Machines
Frozen Sewing Machine Arm/Pfaff Tiptronic 6270
Good morning,
A question to help determine what's happening with your machine(s).
Open the bobbin case so you can see the bobbin area. Begin by trying to turn the handwheel towards you and watch as the needle attempts to go up/down. If you cannot turn the handwheel towards you, turn it slightly backwards then forwards. Does the needle hit the bobbin case as it comes down?
If yes, your machine is out of time and will require a professional technician to repair.
If the above is not the case, there may be thread jammed behind the bobbin case or wrapped around the inner parts of the take-up lever.
Either case - a Pfaff authorized technician would be your best bet for a proper repair.
Best of luck with your machines - it's just awful to not have the at the ready for all our projects!
Happy sewing,
Kim & Linnette
Jul 30, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
687 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
