SOURCE: I have the Coleman powermate 2400 PSI pressure
Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
SOURCE: pressure washer does not spray consistent flow of pressure
Pressure washers have a pressure regulator/unloader that bypasses the water back into the intake when you let go of the trigger with motor running. If you let the machine run for long preiods in bypass the system could be damaged due to heating of the water being bypassed. The water is in a closed loop. The as the unloader wears it will tend to want to bypass which is what is happening in your case. Dirt trapped at the tip will cause this also. Install clean tip to solve problem. If clean tip did not help then try lowering the pressure by turning pressure regulator counterclock wise. If problem is gone then parts are failing but keep using pump. Good luck.
