Question about Zebra Eltron LP 2824 Thermal Printer
LP2824 Zebra printer software
Hi! I just downloaded the Zebra designer version for Microsoft Vista to get this new printer to load onto my computer. I do see under printers that it is on my computer, although now I don't know how to find the content page to enter info to actually print bar codes. Can anyone advise..feeling very foolish!
Try downloading ZebraDesigner Pro here.
It should have a familar MS-Paint type interface. A small learning curve.
Posted on Oct 02, 2008
Kodak EasyShare software
whta is the error message that you get?
Jul 09, 2008 | Computers & Internet
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
I have a Zebra S4M printer and it has always printed fine. I downloaded Zebradesigner software to be able to create a label, but i am having trouble setting up the printer through the Zebra Designer...
you need to load the zdesigner driver from the zebra website, the older zebra universial wont work with zebra designer that why you can't pick it. Designer Driver (32 bit/64 bit, Windows Certified) &dvar3=50
Cut and paste the whole link and paste into the address bar of your web browser or just goto and click drivers and downloads.
Jul 08, 2009 | Zebra Designer Pro for PC
How can I retreive to my computer a form from a Zebra tlp-2642 printer. I want to put it on another printer
There is no way to retrieve the form from your printer memory. I know it's stupid but it's a fact. Best solution is to find the design software used to create the form and just download it to your new printer. If it was designed with ZebraDesigner just load printer driver for new printer, open label file, double click on blank area on display and select alternate printer, then download form
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
My zebra LP2824 Thermal printer is driving me nutty. It skips tags between each printed one. I'm printing on thermal labels that are 1.1875x3.375 (2 side by side) so the total measurements are 2.375x3.375....
possible is not the best printer to work on site-by site labels because the sensors that read the gab are on the midle of the label and possible can't check wen the label start and end. try the printer S4M (sensors on lenf side), or try normal labels and press the botton until flash 2 times and release the botton (calibrate).
Dec 14, 2008 | Zebra TLP 2824 Printer
Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
Oct 02, 2008 | Zebra Eltron LP 2824 Thermal Printer
Trying to print the data from a Mettler Toledo IND690 Weighing Terminal to a TLP2844 Zebra
This printer can be loaded into memory the design and receive the data from the weighing terminal for the desired layout.
Feb 21, 2008 | Zebra Printer 140-751-00000
Printer will not print
zebra have only just started to support vista, you need to download the latest version of zebra designer from zebra(free). drivers are included
Aug 13, 2007 | Zebra TLP 2824 Printer
Zebra Eltron LP 2824 Thermal Printer Logo
1,062 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
