Question about Philips HTS3400/37 System
HTS3400 My phillips system isn't working anymore. The standby light keeps blinking red and clicking. How did you fix this? I'd really appreciate any help. thanks
  • Anonymous Sep 23, 2008
    unit was moved now standby flashes and clicks unit won't power up.
5 Suggested Answers
SOURCE: Phillips HTS3400 blinking red light
there is a capacitor on the power supply that has gone bad, it is a 1000 mf 16v cap and you will notice the top is bulged up a little bit. there are three in a row and this is the center one. Radio shack replacement part for $1.73 and you are back in business. Tim
Posted on Jan 14, 2009
  • 26 Answers
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Posted on Feb 28, 2009
  • 3866 Answers
SOURCE: No sound, no video.
There are several cuase to this issue one being the power supply unit not providing power to the rest of the tv because of a blown capacitor or a resister gone bad. It look like you did some investigation and I can apprciate that but I been around for 20 plus years in this field to know a little more then a back yard fresh out of school tech not saying you are such but however if your the type of person that could repair this your going to need a OHM meter to check current SCHEMATICS to check how much current al you going to need to know about LOGIC BOARDS these will require some know how as well but check the PSU and RCT... Rulds2008 please rate me!
Posted on May 14, 2009
SOURCE: my soundbar (Phillips hts8100) freezes on low pwr standby.
i have also same problem, by that time i am pressing tv/ disc button then it should be okay
Posted on Nov 24, 2009
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Plug in and red light flashes and makes a click sound
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link
Nov 30, 2013 | JVC AV-32850 TV
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Mar 11, 2012 | Philips 42PF9431D/37 TV
Red light blinking system error E74
this might be a hardware failure. try turning it off then back, or try keeping a fan on it when you play on and if that doesn't work call 1800myxbox there you'll find step by step instructions to send it down to texas and get it fixed. if that happens three times you will recieve a brand new xbox 360 that has that problem fixed. also keep in mind to keep your hard drive before you send it to be fixed. i really hope this helps with your problem
-good luck
Jul 14, 2009 | Microsoft Xbox 360 Console
SONY KV34HS510 always worked perfectly but today it wouldn't turn on by remote or button on TV. It makes the same "click" sound which it always did before coming on but it just immediately clicks again to...
You need to bring it to a TV technician. There is a relay inside the TV which can be blocked by any few errors that may occur in your TV, for protection. Only a tech may discover the problem.
May 25, 2009 | Televison & Video
Jun 22, 2008 | Audio Players & Recorders
System will not power on!
My system seems to be locked in stand-by. When I unplug and replug the red power light comes on, but bwhren pressed just starts blinking like in stand-by. Help
Jan 12, 2008 | Philips HTS3400/37B System
Philips HTS3400/37 System Logo
102 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
