Question about Video Game Consoles & Games
THE SCREEN IS NOT TURNING ON ONLY THE POWER LIGHT FOR PSP
  • 135 Answers
Sir, what happened to your PSP prior to this problem occuring? did you accidentally drop it or were you installing something (e.g. newer version of its firmware). If it is the latter prolly it has been bricked and you need a pandora kit to unbrick it (plus of course the universal unbricker w/c you can just download from the Internet). If it is the first then you need to have it checked with a technician to make sure there aren't any broken or damaged internal parts...
Posted on Sep 17, 2008
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
My PSP is not turning the screen on i turn on the screen
What needs to happen is the psp needs to be taken apart so you can get to the lcd to unseat and reseat the lcd cable.
If that doesn't work then the screen is bad and would need to be replaced.
Here is a tutorial on how to replace the screen but you can also use this to get the psp to the point to unseat and reseat the cable:
http://www.llamma.com/PSP/PSPTearDown.htm
Jan 06, 2010 | Sony PlayStation Portable (PSP) Console
How do i reboot my psp?
Have you tried turning on, but then hold the power switch down for around 10-15 seconds or until the power light simply turns off, no flashing. If not, then you should jump on the internet and look for a so-called Pandora Battery and Magic Memory Stick. They will actually install custom firmware on your PSP which you can remove later on, but if you use those, it should unbrick the PSP, so you can use it again.
Sep 24, 2009 | Sony PlayStation Portable (PSP) Console
PSP problem
Try first to remove the battery for about 1 minute and then put it back in and if still no display on the screen and you hear a sound it only means one thing the screen is bad and better have it check from Sony service center for a possible screen replacement...
Jul 10, 2009 | Sony PlayStation Portable (PSP) Console
PSP turned on, black screen, cannot access recovery menu
Your psp screen may have broke you can buy a repair or get it fixed at ebay.com.Type in psp repair and you will see people will fix them for a low cost.
Nov 10, 2008 | Sony PlayStation Portable (PSP) Console
Please fix my psp please
its either your psp is bricked(rendered useless..as entertaining as a brick becuase it wont do anything at all.) or screen came unplugged. try turning it on then turning the sound all the way up and see if you can hear the normal sounds. if you can either the screen is unplugged or ruined. if you cant and it turns off by itself then you have a brick.
Oct 12, 2008 | Sony PlayStation Portable (PSP) Console
Psp problems
u bricked your psp try turning it on with a pandora battery and a magic memory stick ;)
Sep 22, 2008 | Sony PlayStation Portable (PSP) Console
Psp not turning on
theres several things that go wrong with PSP screens.
1:) the lcd backlight has gone.
2:) the lcd screen has gone.
3:) The console has had an unsucsessful firmware update.
And is failing to Boot.
Mike @ Compurepair.
Apr 02, 2008 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
