Question about Motorola Mobility S9 Headphones
S9 headset I can not power on my headset. The only thing it does is blinks at me twice in a green light when I connect it to the charger and it blinks once in green when I take it off the charger. I have no idea whats going on. Motorola didn't even know what it meant.
  • 6 more comments
  • cipher64 Sep 22, 2008
    Same issue here. Has anyone found a solution to it. If it's a bad battery does anyone know where to get a spare and how to replace it.
  • Anonymous Sep 23, 2008
    i have the same problem it blinck twice in green then it stay in red for less than a minute then it goes off! any help plzzzzzzzzzzzzz
  • Anonymous Oct 02, 2008
    Same problem here after about 10 months with these. I see online its a common problem. Moto just avoiding fixing them.
  • Anonymous Feb 09, 2009
    two short green blinks when charging, but does not charge. Any solutions?
  • perfectioncc Mar 02, 2009
    2 green blinks when i plug to a charger, 1 green blink when i remove it???
  • Anonymous Apr 07, 2009
    same here
  • juniorglf Apr 18, 2009
    Thats what mine is doing and can't get it to fix. You ever get yours to work?
  • Anonymous May 03, 2009
    same problem...tried plugging into computer USB and now I get a solid red light. I'll wait 2 hours and try again
I just hooked it up with a usb sync cable to my computer. It was installed and ready to use and the charging light came on. Seems like it is charging as the led went from red to yellow, and it does turn on now. However, it still does not work with the usb cable plugged into a wall charger. If this solution works for others having the same issue kindly post your results.
Posted on Sep 22, 2008
    New Friend:
Plug it in to the computer and let the computer install the drivers. After the driver installs wait a few seconds and it should turn red. What Motorola has done it one of the pins in the usb cable needs to be grounded. Unlike most usb devices that use 2 wires a positive and negative voltage, motorola chargers use 3 wires or more. A computer or motorala specific charger provide this input and all other charges fail.
Posted on Nov 11, 2012
    Problem Solver:
  • 5 Answers
I don't know if this will work of you guys..but mine did...I tried 4 different chargers and everything didn't work..even plugging into the computer didn't work...So i smack the battery part like how you smack a tv remote to work..and i saw light flash..So i plug it back in and it works....this charge problem happen to me 2 times and i did the same trick...i hope this works for you guys...
Posted on Mar 03, 2009
Try using a different charge. The unit is sensitive to power levels. Think it cuts off the charging circuit if the current is too high or too lowl.
Posted on Apr 10, 2009
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Motorola s9 headset wont turn on
Mine is doing the exact same thing. Does anyone know what the problem is? If so, what is the fix.
Apr 27, 2012 | Motorola Mobility MOTOROKR S9 Wireless...
On my motorokr s9 the green light just stay on even when I don't charge it is there a reset button or anything?
This is caused by a power surge. To correct, plug your headset into charge, and then plug into power strip. Trip the switch on the power strip to off. It will cause a drain and turn off your green light and then allow the headset to turn back on.
May 06, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
It is frozen with the green light on
try plugging in the charger to the headset, unplug the charger from the AC. If the light goes out see if the headset will connect.
Worked for me this way
Apr 02, 2010 | Motorola Mobility S9 Headphones
My motorola s9 heatset is not working with acer aspire bluetooth
Your acer does not support Stereo bluetooth. Its different from your common bluetooth headsets.
Jan 15, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
S9 HD GREENLIGHT
The Headphones suffered a short, likely when you were plugging them in or off the charger. The easiest fix is to connect the headphones to your charger cable and then flicker the power...
so if you plug them into a usb charger cable to your pc, then quickly disconnect and reconnect the cable from your pc's usb port... this might not work due to the slowness of recognising the drivers.
if you have a wall charger for this unit, connect it up and then unplug it and replug it @ the wall multiple times. Or use a switched outlet/power strip to cycle the power to the charger quickly...
Worked perfectly for me!
Sep 20, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Sep 16, 2009 | Motorola Mobility S9 Headphones
How do I reset s9....the green light stays on constantly and I cannot connect at all.
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
Cpl. Ramos
Jun 24, 2009 | Motorola Mobility S9 Headphones
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
Green light stays on....headset not turning on
I have had no trouble with mine (3+ months of good use) until today. Same problem you had - green light won't go out, unit won't turn on. Jonsumer's solution got me to thinking, and this worked for me:
1. plug the charger into the wall.
2. plug the headset into the charger.
3. unplug the headset from the wall.
Plugging & unplugging the headset to charger multiple times had NO effect. It was only when I plugged it into the charger and unplugged the charger from the wall that the green light turned off and the headset began to work normally.
Jan 06, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Motorola Mobility S9 Headphones Logo
2,426 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
ka4iup
ka4iup
john h
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
