Washing machine bleaching colored clothes by mistake
I have a Kenmore Elite top-loading washer that is 7 years old. We will put bleach in the bleach disperser and wash a load of whites with no problem. If we then follow that up with several loads of coloreds (without adding bleach to the dispenser), some of the coloreds in the second, third, or even fourth loads will sometimes come out with bleach spots and be ruined. It is not always the very next load that is affected, and most times it doesn't happen at all. The bleach spots are usually small and often appear in the same pattern as the holes in the tub (about 1/4 inch in diameter and about 1 inch apart). The bleach dispenser and solenoid were recently replaced. The only explanation I can come up with is that the dispenser is not releasing all of the bleach when it's suppose to, and then dumping the rest into a subsequent load. But why it creates these spots stumps me. Any guesses as to what is going on here?
  • 943 Answers
Thanks for the question its possible that the bleach disp is clogged and when its suppose to release the bleach some stays hehind and theres still some left over from the last load i would check that thanks the appliance doc
Posted on Sep 16, 2008
Why can't I use liquid color-safe bleach in Kenmore Elite top loading washer?
IF the instructions advise against using bleach in that machine then it is probably because the bleach will affect certain parts / rubbers of the machine and will lead to costly repairs if used.. Try a bleach free soil remover like nappy-san or vanish pink in conjunction with a liquid detergent rather than a powder detergent
Aug 03, 2013 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite smells like mold!
Run a cycle ,no clothes in, with about 3 cups/ 750 ml of bleach in it. How? put a fil a plisticbag with the bleach and set it in the washer. It will tip up when you start the cycle. You should end up with a clean washer and clean empty bag.
Jun 27, 2010 | Kenmore Elite 45986 Front Load Washer
Bleach???
Yes that is where you put it - and NO - it does NOT need to be He if you adjust the amount.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I get bleached clothing
bleach port clogged,,run hot water down the port ..
Nov 17, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
How to use liquid detergent and powered bleach?
You should be using a HE liquid detergent. Does you machine have a dispenser for that? The detergent should go in that dispenser. You can put the powdered bleach right into the drum before you load the clothes. I am assuming this is an all fabric bleach.
Happy Clean Clothes!
Aug 18, 2008 | Kenmore Elite 45986 Front Load Washer
DARK CLOTHES END UP WITH BLEACH DOT STAINS
Hello sa-kap,
yYu said,
Hi, I have a top loading Kenmore Elite washer (don't know model #) from the year 2002. It has the automatic bleach dispenser. The problem is that if someone has washed clothes with bleach sometime during the day and someone else comes along and washes dark clothes, the clothes get ruined with dot bleach stains. It appears that the bleach remains in the washer. Any tips or do I need to buy a new washer? Any help would be greatly appreciated. Thank you
V.C.My problem is similar to that which VCasabona is having. Not just dots occur but often big splotches. It may not even be just a colored load following whites on the same day but, on occasion, it occurs on the next laundry day, a week later with the first load that is not the whites with bleach. Also, my wife adds the bleach to the filled washer (old school, I guess), rather than pouring into the dispenser. My water pressure, which is not at issue, is not what I need to address to remedy the situation. I have noted that the ledge that is part of the floating tub had some build-up of deposits, some of which may have been bleach. These I've reached in with damp cloths and removed as best I can. I've run full, empty loads through hoping this would flush out any lingering bleach. Because the occurrences run intermittently from infrequently to frequently I cannot be sure if any of my attempts to remedy the problem are having any effect. I've guessed at the model # of the Kenmore top load washer we own since Dec of 1999
Sounds like some water is remaining in the tub after the pump gets done emptying the washer.
So its the pump!
The Kenmore Elite is a good washer and I believe worth fixing!
Unless the cost is half the price of the cost of a replacement.
Bless You,
Please write me a good rating before you sign off.
Jun 20, 2008 | Kenmore 24032\24036 Top Load Washer
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
SOME BLEACH DISPENSERS USE COLD WATER TO FLUSH THE BLEACH FROM THE CUP. CHECK THE COLD WATER FOR GOOD PRESSURE. IF THERE ISN'T GOOD PRESSURE, REMOVE THE COLD WATER HOSE FROM THE MACHINE AND CHECK THE SCREEN INSIDE THE VALVE WHERE YOU REMOVED THE HOSE. PUT THE END OF THE HOSE IN THE TUB AND TURN IT ON. CHECK FOR GOOD PRESSURE. CLEAN THE SCREEN AND RECHECK THE WATER PRESSURE AFTER REINSTALLING THE HOSE AND TURNING ON THE WATER. IF YOU STIL HAVE POOR PRESSURE REPLACE THE VALVE.
Apr 07, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
263 people viewed this question
Top Washing Machines Experts
