Question about Sony KP-53HS10 TV
Taking it apart to move
I want to move the TV up a couple of stair cases. Can I take the screen off of the base to enable me to move it in two parts? thank you
  • 70 Answers
Not a good idea but they are bulky it can be done i have done just take your time and put blankets around it
Posted on Sep 21, 2008
FIND A NEW SCREEN FOR VIZEO 55
It is called a display panel--cost of part alone will be more than a new set---it is fatal. Buy a new set.
Apr 02, 2012 | Vizio VF550M 55 in. LCD HDTV
My big screen tv is about 3 inches to big to take down my stairs into my basement. Can it be dissasembled? Are there any sketches on how to dissasemble the speakers? Thanks Don
Yes but it would be easier to widen the stairs and just moving them can stop them from working so if you decide to take it apart just be careful, Manuals are available online but non are free
Dec 02, 2010 | Samsung HLT6187SAX 61" DLP HDTV
I want to move my 65 inch mitsubishi from the ground floor to the second floor of my house where will i get the instruction on how to disassemble it.
Don't disassemble this tv,it have very sensitive CRTS Tubes assemblies.U take it aparts,it will not funsctions the same way again or not at all.Buy another tv smaller lighter take it up stair.
Jun 15, 2010 | Mitsubishi WS-65807 65" Rear Projection...
I actually have an HP Pavillion zd8000 where I need to install a new DVD "D" Drive. I have removed all of the screws, including the ones under the battery, by the Hard Drive, the back base of the monitor...
Generally, the optical drive can be removed without taking the casing apart, just one screw holds it in under the laptop. If yours is one of those that does need to come apart, you will need to make sure that the two screwsat the rear of the laptop are undone. When you take the bexel off where the power button is, there will be two more screws holding the hinge in, they need to come out too. Then you need to remove the LCD screen before the rest of the case will come apart.
Nov 22, 2009 | HP Pavilion dv9000z Notebook
The connection where you plug in the power on my compact presario R3000 laptop is broken. The female part that you plug into is loose and probably broken away from the solder on the mother board it self. I...
Before you pull apart your laptop, check the male connector and power cord of the adapter, check it with a multimeter and or plug it into another Compaq. You could have a broken wire in the power cord, it could save you a lot of work.
To pull apart the laptop, remove the battery, hard drive and CD drive first.
Then remove all the screws from the bottom of the laptop, plus the screws on the back that holds the LCD's hinge to the laptop base.
Take a note of where the screws come from, some may be shorter that others.
The remove the keyboard (the screws should already been removed from the bottom of the laptop).
Carefully remove the plastic cover next to the base of the LCD screen, This may also cover the hinges, if necessary fold the screen flat to enable you to carefully pry this cover up and off.
The plastic top cover is clip fastened to the bottom of the case, carefully prize apart from one side and gradually work around the other sides.
You can now remove the LCD, there are two connects attached to the motherboard, unclip these.
The motherboard is under the keyboard and plastic top cover, there are screws securing it to the plastic base, remove these and you should be able to free it from the base.
Now you can solder/fix the power connector.
I suggest you use a temperature controlled soldering iron.
Don't use too much force, you might crack the plastic parts.
Best of luck and have fun.
Jan 12, 2009 | Computers & Internet
Cabinet removal
Unfortunatly no there isnt. The tv bottom contains all the circuits, color guns, speakers. From where the bottom of the screen starts to the top is all part of the entire cabinet which is molded plastic. The top part contains a mirror and the screen you see as well as possibly a remote sensor. Short of sawing it in half and tossing it away you could take it apart but this would have to be done completely to gain you the most space and could be dangerous considering the high voltage transformer that the unit uses to power the color guns.
Mar 07, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Disassemble Rear Projection TV
well the short answer is : Check the sides of the set see if there is a crack in the middle where you could separate them
Long answer: i would not recommend it even if it does, the screens are sensitive and could get dust inside the screen.
Never taken one apart that far. i suspect most tech don't because of the problems aligning and dust ect.. trying to get it back together.
Dec 13, 2007 | Philips 60PP9202 60" Rear Projection...
Taking apart and moving a 55 inch projection TV
hi do this as last option! there is 30,000v inside the tv!! you can die before you even think about it the only way to do soo is unplug the T.V from the wall for a week at least (so the volt will dissolves) you can turn the tv on its side you will have a problem if it will get a slap or will fall in my opinion just take on its side....but its your decision JUST BE CAREFUL PLEASE!!! good luck
Mar 20, 2006 | Pioneer SD-P55A3-K 55" Rear Projection...
Sony KP-53HS10 TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
