Question about GE Spectra JGBP30 Gas Kitchen Range
Broiler will not light. Oven & top burners work fine
Broiler will not ignite. Oven and top burners work fine.
  • 1 more comment
  • leenches Dec 20, 2008
    My broiler will ignite, but the flame is very low. We have replaced the ignitor and the gas regulator.
  • Anonymous Mar 16, 2014
    top burners not working unless oven is on
  • Anonymous Mar 23, 2014
    WFG361LVB2
  • 943 Answers
Hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Posted on Sep 16, 2008
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Oven will not light - top burners and broiler work fine. Oven igniter glows when oven bake is selected but burner will not light. Is bake igniter replacement by owner practical?
I would first check the amperage of the igniter. If the igniter is pulling the amps it should then the problem is the gas valve. In my experience the igniter is usually the culprit. They are not difficult to change just make sure you unplug the oven because some times there is live voltage on these wires.
Jun 22, 2010 | General Electric Kitchen Ranges
Whirlpool super capacity 465 oven quit lighting
Check the burner ports near the ignitor for blockage. I had one of these units, and the ignitor was not mounted correctly, and caused a similar problem
May 02, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler won't light
gas=replace igniter(top)
electric=replace top black heating element!
Oct 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
426 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
