Sharper Image CD/stereo Model GM807: Unit reads no disc playing original (store bought) discs. It may start playing but stops after a couple of tracks. Trying to get it going again is alomost impossible. How can I fix the lens if cleaning won't help?
  • ttri Feb 28, 2009
    God I wish I could help because mine started doing the same thing, now it won't even turn! I'm about to throw it against the wall. Actually, when I smacked it, it started working again but only for a few days. Stupid Sharper Image, UH!
  • 97 Answers
SOURCE: Various LG DVD Player
Some models of PIONEER cd players had radio frequency problems that caused them to work on and off. Are you near any radio or braodcast towers? Poorly shielded power supplies cause this as well. A weak laser diode in the pick-up assembly in model runs could be the problem. You might want to Google the model number and see if this is common for these units.
Posted on Apr 29, 2007
  • 3422 Answers
SOURCE: Tascam CD A500 'No Disc' error message
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on May 01, 2008
ginko
  • 19396 Answers
SOURCE: I have a set of
Try restarting the whole equipment and see if devices pair together fine on startup.
Posted on Jul 19, 2008
ginko
  • 19396 Answers
SOURCE: Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
SOURCE: Panasonic SA-AK330
Change the spin motor disc
Posted on Aug 17, 2008
My sharper image 3 cd player will not change disc.
Does it play any disc?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 07, 2017 | Sharper Image Audio Players & Recorders
Which fuse is it to take out if the cd player reads unreadable disk for any cd I put in...2006 Hyundai sonata...
Kirk, I am not aware of any fuse to remove to make player work. Try cleaning the lazer/head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CD player doesn read disc
2007 Sonata Ltd CD player won read discs
How to Fix Car CD Player
May 19, 2016 | Hyundai Cars & Trucks
No Disc error
Hello
Clean the lens assembley of the set by inserting a lens cleaning disc into it , and play it at least three times. If it does not help you, the laser pickup unit of the set is faulty and should be replaced with same type and number. The cleanind disc can be bought from electroncic spare part selling shops at your town, and won't cost more. OK.
Jan 19, 2012 | Sharper Image GM402 CD Shelf System
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
Mar 21, 2011 | Durabrand DVD-1002 DVD Player
The CD plays one or two songs and then stops and the sliding doors open
This indicates the CD player is having issues reading the disc. Here's my fix on dirty CD lenses:
CD just says loading
This can be as simple as a dirty CD lens. CAUTION!! The lens is delicate! I wipe CD lenses with ONE drop of glasses cleaner on a Q-tip and, starting in the center, wipe in circles to the outside. Do not press down! Do not force the lens side to side. It will move while cleaning but don't put more pressure than needed to move the lens 3/4 way down!
Its a cheap test to see if there is a fingerprint on the lens. (You won't be able to see it - does not take much)
If this does not help, it means it needs a laser or worse.
Apr 19, 2010 | Sharper Image Slim One-CD Stereo with...
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Won't play recorded cd's
Try this link. It offers resistor changes which are designed to fix your problem of inability to play any CD R. on that model Nakamichi. jacknz0 http://home.cogeco.ca/~niteowl/Nak_MF51.jpg
Dec 31, 2007 | Nakamichi MF-51 5-Disc CD Changer
Apr 27, 2007 | LG DK 9411P DVD Player
CD Player will not play all CD-R discs only ones it chooses. But if the CD is bought from a store it will play it.....if it is burned it usually will not.....even if the cd was just brned and plays on...
It might be an older system that can't read computer-made discs, or it could be a disc incapability. Most old players can't read CD-R discs, even if they can play normal/original CDs. You can try another media but i wont think it will help. Sorry.
Jan 04, 2006 | RCA RS2044 Shelf System
429 people viewed this question
 Grubhead
Grubhead
