Question about Samsung SP-S4243 Television
Samsung SPN4235x/aa Dear Sreekidu, My Plasma TV's Screen went black( dark) suddenly while I was watching one day and the red light at the bottom started blinking instead of being steadily lit.Subsequently whenever I switched it on the light blinked a few times but the screen stays black. A local tech who came and looked at it suggested that it needs a mother board change costing $300 while he charged another 200 for service. Can you help? Can I change it myself and is it true that I need to change the complete mothe board? Can you emial me at srao200296@yahoo.com Shailaja
HDTV GURU
  • 261 Answers
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
It does sound a lot like a buffer board problem, Just which one is the question. Sometimes it is in fact a connection issue. But 1/2 of the screen missing sounds like maybe connection between the 2 buffer boards. It could possibly be the panel. If that is the case. ITs over for that set. But i would suggest first calling samsung and asking them to extend the warranty for 90 days or so. Sometimes they will do this for nice customer such as yourself. 1-800-SAMSUNG. Let me know how this turns out first then we can proceed further if needed. Good luck and keep me posted. Sincerely Jay
Posted on Jan 31, 2008
  • 18 Answers
SOURCE: Samsung 42" Plasma spn-4235 Went black
SOMETHING IS LOADING DOWN THE POWER SUPPLY...COULD BE THE Y-SUS BOARD OR UPPER OR LOWER Y-DRIVE BUFFERS...TAKE THE BACK OFF SET..GIVE IT THE SMELL TEST AND EYEBALL THE FLAT I.C.`S ON THE THIN BOARDS TO THE LEFT OF Y-SUS BD. IF NO BURNING SMELL AND NO CRACKS ON THE FLAT I.C.`S ...TRY REPLACING THE Y-SUS BOARD...NUMBER ONE PRIME SUSPECT...DO NOT POWER UP SET WITH BACK OFF UNLESS YOU ARE QUALIFIED SERVICE TECH...JOE ACE
Posted on Jun 12, 2008
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
  • 12 Answers
SOURCE: We have a Samsung Plasma TV we were watching this
Each pixel of a plasma television contains a red, blue and green phosper. These immite a flourescent light individually to produce a nice bright picture. The odds of all of these pixels dying at the same time is so slight, it is likely to never happen before the return of Christ. So your black screen is another problem. There is an ultroviolet light emitting photo that causes these other photons to give off light. My diagnosis without actually inspecting your unit, is that your ultraviolet photon generator needs replacement. These usually last in an excess of ten years so while it may be a costly repair, if you otherwise are happy with your unit, you may want to repair it. Your only other option is to replace it.
Posted on Jun 28, 2009
circuitworld
  • 335 Answers
SOURCE: sound but no video HPT5054 Samsung
One of your transformers on the inverter board are failing to sustain regulated power to the florescent lamps resulting in a dark picture. Also check the SMD fuses on the inverter board(s) see if they have blown. You will need a continuity meter to check them. You can get one from radio shack and be sure to get one with audible sound....you don't have to replace boards when you can fix them.
Posted on Jul 10, 2009
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Plasma screen suddenly went out
its a lcd ? replace the lcd lamps or the inverter
May 04, 2012 | Panasonic Televison & Video
I have a LG plasma 42PC1D (4 years old). For the
I had the same problem a few months after buying the TV, called LG and they sent a tech to replace two boards in the tv. No further problems since.
Dec 21, 2009 | LG 42PC3D 42 in. Plasma Television
Please Help!! Black Screen, Red Light Flashing
is this a plasma or a dlp tv? if is a dlp a have bad news for you get rid of the tv, if is a plasma then is something different, post the model # anyway to see if we can help you.
caypianan@yahoo.com
Aug 24, 2008 | Samsung FPT5084 50 in. Plasma HDTV
Plasma TV problem - loss of brightness
Yes it can be repaired cost ???? Depends on you on how much your willing to spend on repair.Good Luck. ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | Samsung PS42P2S 42 in. Plasma Television
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung SP-S4243 Television Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
