Question about Sony Walkman NWZ-S616F MP3 Player
No connection on either screen
Recently my walkman is not registering a connection when plugged into my Vaio laptop. The sockets and lead are fine and I'm able to play music but cannot sync both. Am quite a new user and don't know what to do. Any ideas?
  • 5 more comments
  • KiraMeep Oct 06, 2008
    Mine lights up when it is plugged in, but other than that it won't charge or anything. It knows it's connected, there must not be anything wrong with the cable. It makes me sad. :(
  • Anonymous Oct 08, 2008
    i cannot put files on my mp3 anymore because there's no connection between the pc nd the mp3... i don't know what's wrong with this... pls. help...
  • Anonymous Oct 18, 2008
    its plugged in but its not being recognized by the comp or the mp3 player
  • reptone15 Oct 18, 2008
    Its plugged in but its not being recognized by the computer or the mp3
  • Anonymous Dec 29, 2008
    My Player has become unreadable by my computer. I thought this was due to a corrupted file, so I formatted the player to delete the corrupted file. The player is still undetected by my computer. How can I solve this problem?
  • d_roman1011 Dec 29, 2008
  • Kaneko Feb 04, 2009
    Instead of making the two toned noise, I get a sound that is three of the same pitch and it isn't recognizing my player. I've tried different ports and even different computers and nothing can recognize it.
  • 22 Answers
Try using a different usb port
Posted on Nov 15, 2008
Sony vaio no power on
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 05, 2013 | Computers & Internet
Have a sony vaio the wont turn on, nor will any lights come on.
Dec 01, 2012 | Sony VAIO EB Series Notebook
Wont power up no lights
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 05, 2012 | Sony Vaio VPCEA36FM
Plug in not charging
Jul 20, 2012 | Sony VAIO(R) VPCEA44FX/T 14" Notebook PC -...
I have sony vaio PCG-5J6N. I i press the POWER button, there;s is no information appears on my screen, I cannot get inside the BIOS even if i press the F2 key, it is totally blackout. but if i press the...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 30, 2012 | Sony Computers & Internet
I have ordered new battery for my Sony Vaio notebook VGN-CR220E from Amazon.com and when i attached it says plugged in, not charging. please help me
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 04, 2011 | Sony VAIO VGN-CR220E/P Notebook
My sony vaio was running fine, I was just watching a movie on it when it turned itself off. I turned it back on but it went off again after a couple seconds, and after that it wouldn't even start at all....
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Aug 11, 2010 | Sony VAIO VGN-NR120E/S Notebook
Power socket sony vaio
Look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
Feb 04, 2010 | Sony VAIO VGN-NR430E/S NoteBook
Vaio power lead wont allow laptop on
Try turning it on without the battery.
Oct 27, 2008 | Sony Computers & Internet
VAIO VGN-S460
check adapter output also may be problem with dc socket on laptop loose or somthing.
Apr 11, 2007 | Sony VAIO VGN-S460 Notebook
Sony Walkman NWZ-S616F MP3 Player Logo
56 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
