Question about Microsoft Xbox 360 Console
Screen was all fuzzy and red ring was at bottom right side!
  • kabbie69 Oct 05, 2008
    i have the exact same problem but way worse. the screen is fuzzy in the game and some games (gta IV) the colour is terrible, i can barely even see anything except red spots. plus the shadeng is super pixely. i have a bad feeling it is the GPU. you claimed that you had a solution, could you share that with me?
  • Anonymous Dec 21, 2008
    Loads with a wierd red dot screen followed by "Fuzz" that looks like snow (though very annoying) on the Halo 3 map Avalanche.
  • 659 Answers
From the description you stated it sounds like the following error code
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
  1. Try restarting the console.
  2. If restarting the console does not resolve the behavior, follow these steps:
    • Turn the console off.
    • Unplug all the power and AV cables from the console.
    • Unplug the power cord from the wall socket.
    • Firmly reconnect all the cables.
    • Turn on the console.
  3. Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green
try that and if nothing works I have more to follow.
Posted on Sep 16, 2008
I have an Xbox 360 and when playing games my picture is fuzzy
Posted on Mar 28, 2009
What u hav 2 do is open ur 360, [ur wanerty will be over if u hav had it for over 1 year] u will need to watch videos on how to open n 360, then just watch videos on how to fix the RED LIGHT OF DEATH its the same way to fix ur problem, turst me i had the same problem n i fixed it like dat 2day. lol
Posted on Dec 19, 2008
Screen is red n black n fuzzy
Sound that the COF IC is faulty. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 850 posts to different brand TVs now.
Faults plasma TVs are given in detail here with illustrations. It is very difficult to provide all of those be this window. Just visit the site and find it.
Sep 27, 2012 | Philips 42MF230A/37 42 in. Plasma HDTV
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
Red flashing light on bottom right on 360 elite (e73 error)
X-clamp Fix. Also make sure you have all four heat patches attached to your memory chips. If you don't have any buy some. They sell them on the net.
Jul 14, 2009 | Microsoft Video Game Consoles & Games
Fuzzy pics
Go into your camera. At the bottom of the screen, on the right side, the word options shows. Press the blue dot below it and set the effects for whatever you want.
May 22, 2009 | Motorola Mobility W375 Cellular Phone
One red ring
IF U TURN IT ON AND IT STAYS LIKE THAT THAT MEANS U NEED TO CALL MICROSOFT AND TELL THEM U HAVE RED RINGS
Apr 10, 2009 | Microsoft Xbox 360 Console
Free big screen, is it worth it to fix?
take the front cover off.two hidden screw at each corner or on the sides .now take off cover in middle of set.two the right you'll find a small box , it will have 3 adjustments on the top and three more at bottom.the bottom ones are your screen controls.the middle is your green and on the right is the one you turn counter clock wise.warning ...turn that control a hair .that will solve the problem
mr.tv.inc
1-866-217-6788 harry
Feb 18, 2009 | Sony KP-57HW40 57" Rear Projection...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Camcorder
I have a Aiptexk pocket DZO-V58, it will power on then 5 sec later it power off. Can anyone help!!
Thanks,
Susan B.
Jul 24, 2008 | Aiptek R-PKDV58 Flash Media Camcorder
1 redlight flashes clearly red at bottom right hand side of the power ring,and 2 other dim red lights are flashing,only the 1 in the bottom right is bright though.it happened 2weeks ago but i tryed it...
Do you get an error message on your tv screen? 1 flashing red light means there is a hardware failure such as your DVD drive hard drive, dashboard error ect. Not much can be done about this issue besides having microsoft fix it.
Apr 23, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
326 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
